Lower engine knock?
Old Nov 20, 2004 | 11:51 PM
allen410's Avatar
allen410
Lower engine knock?
What would cause a lower engine knock? Can the engine or part be repaired without a complete overhaul? The engine starts and runs but it has a knocking sound. The sound starts off as a slight tap and once the throttle is pressed, the knock comes in. It sounds as if there may be something loose? Please help as I am new the internal working of a motor.
Old Nov 20, 2004 | 11:52 PM
MustangGT221's Avatar
MustangGT221
A stethescope (sp) is the best to use to determine where an engine knock is located. Once you know where it is, you'll be more able to determine how to fix it.
alloro
Mar 10, 2017 02:51 AM
sitiakab
1997 - 2003 F150
May 29, 2012 05:50 AM
camoflauge
13
Dec 20, 2002 01:02 PM
firestorm
Aug 19, 2002 05:48 AM
therigwelder
Jul 18, 2001 10:13 PM
