How do you pull that thing out without breaking it?
Originally Posted by barebackjake
i just take a screwdriver and GENTLY work it out. the plastic housing can break pretty easy your better off thying to wiggle the thing out with your fingers though.
Originally Posted by dieselstroke
i believe on the engine side across the firewall from inside the cab. There is 2? more
bolts on the wiring harness to computer that you also have to remove.
I'll give it a try again today.
I haven't had any problems with the engine dieing but I noticed the Tach doesn’t move when cranking to start and every now and then I get a longer crank than normal to start. And, every once in a while I get a start failure, turn the key off and crank again to start. <O</O
Is the Tach not moving when cranking a sure tale sign the CPS is going bad?
Well, I don't know. I was looking at the TYMAR filter system and found were he'd written about the CPM and the Tach moving. He said that on 2002's and up the Tach probably won't move when cranking. I did get that little bugger out of there though. Didn't seem to damage the old one, so I'm going to take the advise and keep it as an emergency part behind the seat.
Originally Posted by bodabdan
I have heard that there are 2 P/N's for the CPS. The wrong P/N can sieze in the hole due to metallurgical properties. Maybe that had something to do with your's being stuck?
Originally Posted by Orezona
Hey psdpower,
The screwdriver/twist idea was perfect. That thing came right out. I'd been pulling on it. The truck seems a little smoother now, but the Tach still doesn't move when cranking.
Thanks everybody.
Thanks everybody.
haven56
11-23-2012 06:46 PM
blue88EB
06-30-2003 10:00 PM
