Thirsty F-150 Please Help!!
Old Nov 19, 2004 | 12:02 PM
Bullet-Nose's Avatar
Bullet-Nose
Hi Folks,
I'm a new member on this forum, just bought a real nice, but very thirsty, 93 F-150. It's a six cyl 4x4 XLT with all the bells and whistles. The problem is I'm getting about 8MPG. From what I've found here 10 is about average. The air filter and plugs are new, what else can I do to improve the milage? I do not lead foot it.
Are there any after market chips? They have them to improve performance, any to go in the other direction?
Thanks in advance!
Old Nov 19, 2004 | 12:05 PM
RR4E's Avatar
RR4E
Change all your fluids(diffs, t-case, trans, engine oil), add new wires, cap and rotor to the ignition, and see if that brings it up. Also check to make sure your brakes are not dragging, and maybe even go as far as re-packing the front wheel bearings. Lubrication is one of the biggest single contributors to poor fuel mileage, especially in a 4x4. Most people change the engine oil, but forget about the differentials, t-case and trans until there's a problem. May want to check the timing as well, and it never hurts to run a couple of jugs of injector/carb cleaner in with your next few gas fills either.
Old Nov 19, 2004 | 05:49 PM
c_rossman's Avatar
c_rossman
I would think you should be getting atleast 14mpg with this truck. I get 12mpg with my 460! My 1990 F250 with 4.10 gears 300-6 gets 12mpg, 3speed auto no overdrive!
Old Nov 19, 2004 | 05:50 PM
c_rossman's Avatar
c_rossman
I would start with the timing, pull the engine codes. go from there.
Old Nov 19, 2004 | 09:33 PM
low-side's Avatar
low-side
I got 15mpg highway with a bad o2 densor and a bad coolant temp. sensor. Do the usual: ignition and filter tune-up, fresh fluids, free brakes, and correct tire pressure.
Old Nov 26, 2004 | 12:53 PM
Bullet-Nose
Thqanks!
Thanks for the suggestions. Changed the air filter and fluids, corrected tire pressure, now getting 10MPG...still bad!
Old Nov 26, 2004 | 01:31 PM
ford5.8's Avatar
ford5.8
Also make sure your cats are not plugged and a free flowing muffler would probley help..I average 16mpg with my 96 5.8L 4x4 excab..
Old Nov 27, 2004 | 04:37 AM
MustangGT221's Avatar
MustangGT221
I've gotten 16 hwy on my F150 4x4 with 35" tires, 6" lift, 4.10 gearing, and a basically stock 302. My buddy's 96 F-150 I6 with about 60k miles, gets about 15 mpg city/hwy....8 is definitely bad.
You might want to do a compression test, you may have something internally wrong....
How long of an average did you take to arive at that 10mpg? I assume you know you need to measure mileage over a few tank fulls in order to get a decently accurate number....
Old Nov 27, 2004 | 10:18 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Compression check would be good, tune up, fluid and filter changes need to be done when due, check for codes and check fuel pressure. Big heavy vehicles do not get good mileage, don't expect too much. If you get in the 12-13mpg range overall you are probably doing pretty good. Load, altitude, weather, there are many factors that affect mileage.
Old Nov 27, 2004 | 10:22 AM
Dr_Sin's Avatar
Dr_Sin
Well said HardScrabble...Hey and whats your mileage? Heeeheehe
Old Nov 27, 2004 | 12:31 PM
phoneman71's Avatar
phoneman71
Try changing out the oxygen sensor--a bad one would cause low MPG.Should be changed every 50k miles--I hear.
Is the speedometer/odometer correct? Do you have factory sized tires/wheels?
Old Nov 27, 2004 | 01:18 PM
Bullet-Nose
Oxygen sensor and codes are next on the list. I'm running a set of Michelen(sp?) ATVs. Maybe the aggressive tire thread is contributing to the poor milage.
Old Nov 27, 2004 | 06:48 PM
MustangGT221
Like I mentioned, I've got 35" mud terrains (pretty aggressive tread), 6" lift (terrible aerodynamics), and I got 16 on the highway w/ a stock 302 (this is also a heavy F-150, 800 or so lbs more than a normal F-150)....the tire isn't killing your gas mileage that bad.
Old Nov 27, 2004 | 10:54 PM
blueovalwonder's Avatar
blueovalwonder
i have a 1994 f150 with the 4.9 in it...i get around 11-13 in the city..never really taken it out on the highway much (just got it) i think it probily will make in the neighborhood of 16? just guessin.. i dont really care much, it is VERY reliable. by the way i have 32 inch tires all the way around and 3.55 gears...this truck can pull like crazy..so much tork for a 6 cyl...
Old Nov 28, 2004 | 05:45 AM
tex94F250's Avatar
tex94F250
Just wondering, manual or auto tranny? If manual check you clutch, pressure plate, t/o bearing adjustment. If auto and you've already changed your fliud and filter, try adding Slick 50 tranny treatement for high mileage vehicles. Also check the adjustment of your parking brakes, cables for bnding anywhere etc. Another thought: A friend of mine drives to work the same route I do everyday and he has a 300 six in his swb 2wd and was getting 9-10 mpg. (He abandoned a Dodge Ram for the Ford mostly due to gas mileage.) I average 12-14 mpg when running normally and I'm satisfied with that. I looked into his cab one morning and noticed the overdrive selector on the shift lever was lit. I reached in and pushed the button in the end of the lever and his gas mileage went to 14!
tunaluvr
Nov 10, 2023 08:33 AM
SasquatchF-250
General Automotive Discussion
32
Jan 19, 2006 08:35 AM
Arby
81
Aug 22, 2005 07:50 PM
dinosaurfan
20
Nov 19, 2000 12:06 AM
