Sponsored by: Real Truck
Transmission Temp Sensor
Old Nov 19, 2004 | 12:03 AM
mnero's Avatar
mnero
Question Transmission Temp Sensor
I'm planning on installing a autometer trans temp guage. I've read all the post here and everyone says to mount the sensor probe on the driver side of the transmission housing. I wonder if that is the best location?
I would think the fluid leaving the transmission, going to the cooler, would be the hottest (worst case) temperature. I wonder if anyone has installed a tee fitting or manifold in this line running to the cooler?
Maybe the trans housing location gives the same reading?
I would like to know what others have done. Thanks for your time and thoughts.
2002 7.3PSD 4X4 Crew Cab.... towing 9500-10000 lbs.
Old Nov 19, 2004 | 07:09 AM
FortyFords's Avatar
FortyFords
You could install a spin on filter with a temp port also in that line going to the cooler.
I have a manual trans with temp guage in the pto plate.
Rich
willis72
Oct 24, 2014 07:47 PM
Muffinman
Aerostar
Oct 12, 2012 06:34 PM
shuttlevalve
Jun 16, 2010 06:35 PM
Edmund
Mar 14, 2006 08:12 PM
mnero
Nov 23, 2004 09:06 PM
