Cleaned Maf and Throttle Body
Old Nov 18, 2004 | 03:15 PM
vfrocket's Avatar
vfrocket
Thumbs up Cleaned Maf and Throttle Body
2000 Ranger 3.0l Flex Fuel
Cleaned the Maf today, just becasue I have 115000 miles on this truck, so first after securing the proper tamper proof torx tip bit (#20), I removed the MAF. The picture did not come out, but the sensor was shiny clean. this was a supprise since I use a K&N oiled air filter. It really did not need to be cleaned but since I had it out, I shot it with some electrical contact cleaner and re-installled.
Next I set out to clean the throttle body, man it was dirty!
Here it is after I cleaned it... note pointer to DPFE sensor for thoes who are wondering where that is located.
After cleaning.. it was a little hard to start, I assume to burn off the residual TB cleaner, but there is a noticable difference in throttle response, and the engine idles very smooth now.
I was going to do the Throttle Cable mod but I found that it was not necessary after my helper (My father) put the gas pedal to the floor, and the butterfly valve on the TB was wide open.
VFROCKET
Old Nov 19, 2004 | 01:03 PM
vfrocket's Avatar
vfrocket
Just an update... after driving last night, the engine is running great! cleaning the TB did produce some noticable results. Most notibly, the engine starts very quickly, and smoothly. It fires up after the starter has been engaged for less than a second!
Old Nov 19, 2004 | 09:41 PM
Rockledge's Avatar
Rockledge
Sounds like your MAF cleaning was a success. And the TB looks nice and clean now, too, which should help with throttle response.
Both are worthwhile maintenance items that you won't find in any manuals.
Old Nov 20, 2004 | 01:32 AM
vfrocket's Avatar
vfrocket
I had to wipe it a little with a rag, as well as open the butterfly and clean where the valve seats. I was a little supprised at how dirty it was, and how clean the MAF was, the MAF looked brand new... anways running great.
Thanks, I thought the pics might be good so the others could see what a real dirty TB looks like.
Old Nov 20, 2004 | 10:50 PM
silvapain's Avatar
silvapain
The dirty TB is a result of the EGR system. [Sarcasm] Thank You wonderful emissions regulations. [/Sarcasm]
Just be careful wiping the TB. THere is a thin film over the butterfly plate that can cause idling issues if it is damaged.
knotez1
2004 - 2008 F150
Sep 29, 2013 08:51 PM
optikal illushun
64
Sep 11, 2008 07:13 AM
DROOPY209
17
Jun 28, 2008 05:11 PM
Captchnk
3.0L V6
Oct 31, 2006 11:07 AM
barry s
Aug 18, 2006 12:27 PM
