5.8L coolant flow
Old Nov 17, 2004 | 11:23 PM
whatdyisit's Avatar
whatdyisit
5.8L coolant flow
I have a 93 Bronco witha 5.8L. Coolant is flowing through the upper intake through the hose that runs over the radiator and into the radiator fill tube. Is this normal? It leaks when I rev the motor, is there a chance that I have a bad cap. I am hoping that I dont have a blown head gasket. Any info would be helpful.
Old Nov 17, 2004 | 11:46 PM
mako5972's Avatar
mako5972
Where does it leak from? That will help others to help you.
Old Nov 18, 2004 | 07:11 AM
EPNCSU2006's Avatar
EPNCSU2006
That doesn't sound normal. You are talking about the filler neck on the radiator where the cap goes, correct? That hose should go to the overflow bottle, not the throttle body. The hoses should connect to something very near where the inlet and exit are in the throttle body.
Old Nov 18, 2004 | 12:24 PM
gatesj's Avatar
gatesj
If it's running through the throttle body itself that's normal, it's designed to do that to keep it from icing up.
Obviously the leak isn't normal though.
Old Nov 20, 2004 | 06:31 PM
whatdyisit's Avatar
whatdyisit
It’s not the hose that comes off the filler neck. There are 2 or 3 hoses that come off the neck. This one comes from somewhere in the upper intake. The flow out of the upper intake hose is so strong it blows out of the cap. I replaced the cap and it still spews out when I rev above 3000. Does anybody know if the coolant is supposed to flow through that hose at all? Thanks
Old Nov 20, 2004 | 11:56 PM
MustangGT221's Avatar
MustangGT221
I wonder if there is a blockage in the system causing a pressure buildup which is why you're getting water coming out at such a high pressure.
Old Nov 21, 2004 | 08:47 AM
EPNCSU2006's Avatar
EPNCSU2006
do you have any pictures of it?
Fixnstuff
Nov 12, 2018 11:23 AM
RP27G8G
Modular V8 (4.6L, 5.4L)
13
Mar 18, 2017 11:14 PM
Montync
Oct 7, 2015 02:39 PM
tabijan
Jan 25, 2014 11:13 AM
speedtrapp
Oct 8, 2012 12:49 PM
