Sponsored by: Real Truck
Fuel Tank Question
Old Nov 17, 2004 | 09:15 PM
iceb52!'s Avatar
iceb52!
Fuel Tank Question
I have an 04, F250, CC, Lariat, Fx4, short bed. The manual says it has a 29 gallon fuel tank. I routinely put between 32 and 33 gallons in if I fill it all the way to the filler neck. I run it until the "lie-o-meter" says about 25 miles to empty. The gauge is pretty much on "E." The first 27 gallons or so go in very quickly (2 minutes at the truck stop). The next 5-6 gallons go in very slowly. Foam rises up in the filler neck and then recedes slowly. It takes about 8-10 minutes to put in the last 5-6 gallons. I have to run the nozzle at a trickle to keep it filling without the foam rising up.
I assume there is some reason the tank is behaving like this. Does Ford not want me to put that much "extra" diesel in the tank. Am I hurting anything by filling all the way to the top? Anyone else noticed this. I use different stations and I always put about 32.5 gallons in at fillup.
Is there anyway to modify the tank so I can fill it up quicker? Any comments would be appreciated.
RB
Old Nov 17, 2004 | 09:38 PM
02superstroker's Avatar
02superstroker
Why don't you save yourself that extra ten minutes and go with 5 gallons less? seems like a pain in the neck to me...
oh nevermind... you have the smaller tank, i bet filling her up that often is also a pain. Have you considered a second tank?
I also think there is a mod for the vent tube or something that allows that extra diesel to go in easier. Might try a search on here and see what you can find.
Old Nov 17, 2004 | 09:39 PM
refuse2's Avatar
refuse2
there's a mod you can do look for something called the harpoon mod and all it is saying is to drop the tank and cut the vent that goes up to the filler neck and put it back together. I did mine and I can fill it up like a gas now and not have to worry about it.
refuse2
Old Nov 18, 2004 | 02:06 PM
kw5413's Avatar
kw5413
Choctaw Bob has all the info for harpooning your fuel tank. Removes foaming issues.
Check his gallery or PM him for instructions.
Good luck
Old Nov 18, 2004 | 05:17 PM
iceb52!'s Avatar
iceb52!
Thanks. I have never heard of "harpooning" the tank but will give it a try.
What about fitting 32.5 gallons into a 29 gallon tank. What's up with that?
Old Nov 18, 2004 | 05:21 PM
mrc59's Avatar
mrc59
Same thing, the 29G is full to click off. If you top it to the neck you can squeeze a couple more G in.
Old Nov 19, 2004 | 08:13 AM
kw5413's Avatar
kw5413
My tank is rated for 38 gals...only let it get real low once and I topped off at a little over 40 gals.
weldingtofabrication
Oct 1, 2012 05:07 PM
rickatic
6.7L Power Stroke Diesel
19
Nov 12, 2010 11:32 AM
CruiserClass
Jan 23, 2008 02:43 PM
Moe Howard
6.4L Power Stroke Diesel
Sep 4, 2007 01:17 PM
SBV45
Aug 10, 2004 07:12 AM
