Explorer rear
Old Nov 17, 2004 | 05:34 PM
Troniks's Avatar
Troniks
Explorer rear
To anybody that has a explorer rear installed in a 53-56, could you tell me the pinion offset.
Old Nov 17, 2004 | 06:32 PM
tip49's Avatar
tip49
Pinion offset
I measured the pinion angle of the 2000 Explorer diff I installed in my 1950 F47, before removing it from the Explorer frame; measured to be 8 degrees.
all that would change depending on what front and rear suspension changes you did, and alterations to frame height. s
Hope this helps; my O-pinion only
Tom
Old Nov 17, 2004 | 06:39 PM
nomadshirt's Avatar
nomadshirt
Tip49,
What driveshaft did you use? I have a rearend out of a 01 explorer and I will be using a C-4 trasmission.
Old Nov 17, 2004 | 06:40 PM
Troniks's Avatar
Troniks
What I had meant was the offset from the frame center, not the pinion angle.
Old Nov 17, 2004 | 06:46 PM
Troniks's Avatar
Troniks
You can get a flange addapter, " National Drive Train, Spicer P/N 2-2-1379." I got this info from a jeep site.
Old Nov 17, 2004 | 07:53 PM
rtcalabrojr's Avatar
rtcalabrojr
Darksider
what do you mean adaptor for the flange? i kept the donor driveshaft so i would have a match to the diff. i have a c6 trans. RT
Old Nov 17, 2004 | 11:29 PM
CIAF's Avatar
CIAF
HUH??? offset will not matter. It will land where it lands. Just be certain ro center the axle in the chassis sise to side. The center of the pinion will be offset to the right ( Passenger) just as in the Exploder. Look at the pinion article in J.Niolon gallery. Just fillow the directions. Mine is 3 degrees by the way. My eng/tran is 2 inches to the right ( Volare), the pinion center is about 4" to the right.
Old Nov 18, 2004 | 06:50 AM
mt54's Avatar
mt54
As El Cabron stated the pinnion will land where it needs to be when centering the axle in the frame . Then you will need to mount the engine and trany to suite.
Mike
Old Nov 18, 2004 | 04:01 PM
Troniks's Avatar
Troniks
Thanks but the four inches will not work for me. The way I want to mount the air spring brackets, one will interfere with the center section.
Old Nov 18, 2004 | 11:26 PM
CIAF's Avatar
CIAF
Well Tronic, perhaps I'm confused, I just went out to my truck and took a look at the exp rear, and then a friend then brought a set of bags over and there is LOTS of room. I now wonder what you are refering to. You may note that a lot of rear drive cars are offset due to ring size/location. Many offset 9" ford rears are bagged. Maybe you should look at the "Shockwave" at: www.ridetech.com PS I have dig pics of a top view with no bed on. E-M on request. E.L.
