Anyone try the Protech EZ lift spacer?
I was cruising another forum and came across a link to www.protechezlift.com. Their leveling kit is a little more expensive but I personally like the thought of an aluminum spacer.
Do you all think the 3" would put too much of an angle on the cv's. I'm just looking for a solid, cheap means to running 35's until I can get my CST 8".
Thanks, Jerry
Thanks, Jerry
Thanks for the replies.
With the 2.75", was your truck completely level or still had a slight rake. I really want the truck level. Do you think the 3" would put the front end higher than the rear?
Also, other than the ride being a little stiffer regarding the comment of the strut being maxed out, would this cause any other problems. I have searched the forums and most seem to be running 2.5" and I belive some with the autospring stated they had some control arm issues. Any comment? Thanks, Jerry
rockcrawler_101
06-27-2011 02:55 PM
