Anyone try the Protech EZ lift spacer?
I was cruising another forum and came across a link to www.protechezlift.com. Their leveling kit is a little more expensive but I personally like the thought of an aluminum spacer.
Do you all think the 3" would put too much of an angle on the cv's. I'm just looking for a solid, cheap means to running 35's until I can get my CST 8". Thanks, Jerry |
The 3" would take almost all of the droop out and be real close to the end of the shock travel. It shouldn't be a problem for the cv's. I run 315/70/17 BFG's on stock wheels and they dont rub so you just save your money for the CST 8"
Hope this helped |
I bought protech's 2.75" kit, and loved it until i just got my 6" suspension.
I HIGHLY recommend their product. I ran 315/70/17's with it. |
Thanks for the replies.
With the 2.75", was your truck completely level or still had a slight rake. I really want the truck level. Do you think the 3" would put the front end higher than the rear? Also, other than the ride being a little stiffer regarding the comment of the strut being maxed out, would this cause any other problems. I have searched the forums and most seem to be running 2.5" and I belive some with the autospring stated they had some control arm issues. Any comment? Thanks, Jerry |
