I have a 2001 supercrew 4x4 with a 4"inch suspension lift. I just purchased a set of tires, 315/75R-16 size, and soon realized that the 4" lift is not enough as the front tires rub on the front bumper when turning a tight corner. The rub is very minimal and I will soon be trimming the plastic skirt but I was reading where if I were to adjust the torsion bars I could possibly gain a couple of inches IF they are not already maxed out. All I really need is perhaps one inch I think. I know that if I did that the side effects would be a rougher ride but my question is would I need a re-alignment of the wheels to compensate for a different angle the tires would be in? The article I read did not mention if it would affect the camber or if this should be taken in consideration. Does any one know?
yes cranking the torsion bars does change the camber but on many fords there is a bolt to adjust the camber some there isnt though so i would find that out first before you crank them up also make sure your CVs arent running at to high of an angle.
Thanks for all the replies. I went ahead and had a look at the torsion bar adjustment and it seems that they are already maxed out, then it hit me, the suspension lift is a 4" Trail Master but that does not come with rear blocks, only an add on spring to give it a 2" lift in the back but there is a 3" lift block in the back as well, I think that the torsion bars were cranked all the way up to accomodate the blocks in the rear so in all it probably has a 6" lift! Now about it riding crappy, they fixed this it seems by putting on those adjustable shocks (Rancho) so the ride is not at all bad, a bit on the firm side, but nothing to really complain about.
