Sponsored by: Kumho
Tire Rub.
Old Jun 10, 2003 | 07:49 PM
Jimmy Dean's Avatar
Jimmy Dean
Tire Rub.
My 91 has stock suspension but 33s on it. It is a 4x4, When turing the wheel all the way I have tire rub on the Torsion bar I think it is? back behind the axle, going straight back from the spindle? towards the cab. As it is part of the suspension, would a lift cure this rub? or should I get spacers or deeper reccesed wheels? Thanks
Old Jun 10, 2003 | 08:50 PM
jeffd85150's Avatar
jeffd85150
Tire Rub.
my '85 150 does the same thing,rubs when you turn wheels to right or left.i personaly don't worry to much about it since they don't rub to bad. in your case,go with wheels with a different
backspacing to push the wheels away from the radius arms.
don't think lift would cure problem, unless different arms are installed. my '85 has 33's on it & taller coils with quad shocks,&
they still rub. just a suggestion.
Old Jun 10, 2003 | 09:04 PM
Jimmy Dean's Avatar
Jimmy Dean
Tire Rub.
Ok that is what I figured. Oh well, I miught just go with 1 inch spacers for the time, I do not have the moey for new wheels. It has on after market wheels White Farm wheels with less back spacing, bringin the tires in some.
Old Jun 10, 2003 | 10:40 PM
mrwizard's Avatar
mrwizard
Tire Rub.
Before you stick any wheel spacers on, make sure you will have enough stud left sticking out to get the lug nut on securely.
Old Jun 11, 2003 | 12:10 AM
MustangGT221's Avatar
MustangGT221
Tire Rub.
Spacers are a bad idea, they are even illegal in Massachusetts. Lift doesn't help much, I have one and I have special radius arms that are bent in to avoid that. You just have to get the right spacing on the rims.
Old Jun 11, 2003 | 03:38 PM
Jimmy Dean's Avatar
Jimmy Dean
Tire Rub.
Ok thanks Mustang
Old Jun 11, 2003 | 03:46 PM
jbalestri's Avatar
jbalestri
Tire Rub.
Spacers = bad idea
I was told the they move the weight out on the spindle, thus causing premature wearing on the spindle and bearings. I don't know if it is true or not, but I had a Bug with 4bolt to 5 bolt adapters and Cragar SS 5 spoke rims. The spindle had a grove in it from the spacer/adapter I was told. I know it is a different setup, but take it FWIW.
Old Jun 11, 2003 | 06:02 PM
Jimmy Dean's Avatar
Jimmy Dean
Tire Rub.
So then either a deeper rim or get bent arms? wher can I get those arms or torsion bars our what ever they are?
Old Jun 11, 2003 | 06:59 PM
mrwizard's Avatar
mrwizard
Tire Rub.
On the pre '97's they're called radius arms. Just about all of the companies that make lift kits have them. I'm not sure how they would work without a lift though. I'm sure the companies customer service people could answer that though.
Old Jun 11, 2003 | 07:10 PM
Jimmy Dean's Avatar
Jimmy Dean
Tire Rub.
Well, I am planing on putting on a small lift, but I am also considering putting in a straight axle for strength and integrity
sawtooth
Sep 18, 2013 07:51 PM
Xistenz
1983 - 2012 Ranger & B-Series
Dec 8, 2010 04:31 PM
MICHAELHARPER11
15
Feb 4, 2009 12:14 AM
hines182
Dec 6, 2006 08:02 PM
just_brian
Jan 6, 2004 08:28 PM
