5 speed transmission problem
Old Apr 8, 2002 | 04:31 PM
Burnsides's Avatar
Burnsides
Old Apr 9, 2002 | 10:03 AM
88_150's Avatar
88_150
I have a 94 ranger with a 5 speed trans. There is a whining noise in 1st,2nd,3rd,& 5th. 4th gear is quiet. anyone have any ideas, I just had the gear box oil changed but the problem is still there.
Any ideas?
Thanks
Bill
Old Apr 9, 2002 | 10:32 AM
aksniper's Avatar
aksniper
I know this is kind of a stupid question but is it at all RPM levels or certain ones? Is it constant when in the gears or whine on/off intervals? Is neutral quiet too? What size engine? Just curious, plus might help get help sooner.
James
Old Apr 9, 2002 | 12:47 PM
88_150's Avatar
88_150
Thanks for the reply James,
It is a 3.0 and it happens @ all RPM's. It is just a constant whine when the clutch is engaged except for 4th gear. For now I've been just crusing in 4th gear.
Old Apr 9, 2002 | 01:29 PM
greenpus's Avatar
greenpus
I am curious as to what fluids they put in your tranny.
MERCON ATF or compatible is the only one recommended by Ford
Old Apr 9, 2002 | 10:58 PM
XLT4Banger's Avatar
XLT4Banger
Maybe it's your power steering pump. Mine whines exacly when your's does. My power steering pump has some air in it I can't get rid of. When you're in 4th and 5th, you're RPMs aren't as high. Let me know what you figure out. -Kevin
Old Apr 10, 2002 | 10:38 AM
88_150's Avatar
88_150
I decided to stop at the Trans. shop and let them diagnose the problem. They are quite sure it's the center bearing in the tranny, it is used in 1st, 2nd, 3rd, & 5th gear. 4th gear is direct drive and does not use this bearing. So I guess its time to look for a rebuild
Anyway, I thank everone for there input.
Bill
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
