Electronic speedometer from a C4?
Old Nov 16, 2004 | 09:33 PM
billyjoe's Avatar
billyjoe
Due to some space considerations I would like to swap in an electronic speedo from a newer vehicle, is there a speedo sending unit (VSR I think it's called) that will retrofit into a C4 trans? Obviously I will have to use the newer speedometer too but that is a lesser concern. Thanks for any advice you can give.
Old Nov 16, 2004 | 09:43 PM
ms_michelle's Avatar
ms_michelle
You are in luck, they do make a Hall effect sensor that will fit the C4 C-6 trannys. I have one on my 56. My 56 has a C6 and VDO gauges. I have also installed a cruise control. It has an electronic sensor for the speedo that plugs right into the C-6 just as the Ford speedo did. IT has a thru way, meaning you can also install a speedometer cable to it. The speedo cable is needed for the speed sensor of the crusie control. If you need more info e-mail me off line.
Michelle
Chelle's 56 Hauler
Old Nov 17, 2004 | 09:44 AM
billyjoe's Avatar
billyjoe
I sent you an email asking about what pieces you used....hope to hear from you soon. Thanks.
Old Nov 18, 2004 | 09:32 AM
billyjoe's Avatar
billyjoe
I realize that VDO and many other aftermarket gauge people make sensors and gauges for my application but my question was 'is there a sensor from a newer vehicle which will fit my C4'? Maybe one I can get from the wrecking yard?
Old Nov 18, 2004 | 10:24 AM
ms_michelle
As far as a newer type vehicle with an electronic sender that will fit the C-4, I can't answer that question. What type of speedometer are you going to use?
Michelle
Chelle's 56 Hauler
Old Nov 18, 2004 | 12:13 PM
billyjoe's Avatar
billyjoe
I planned on fitting whatever speedo that came from the same car as the sensor (as long as it is round and analog).
Old Nov 18, 2004 | 01:17 PM
ms_michelle
Billy, I really don't know what to tell you except to go to the junk yard and start digging around to see what you can come up with. If all else fails you can always do as I suggested. As I said I think I have a sensor here that you could use in your application.
Michelle
Chelle's 56 Hauler
Old Nov 18, 2004 | 02:01 PM
billyjoe's Avatar
billyjoe
You didn't really say but I'm guessing that your sensor is a VDO unit, is this true? How much was it?
Old Nov 19, 2004 | 06:50 PM
ms_michelle
No the sensor is not only for VDO. It is a universal sensor.
Michelle
Old Nov 20, 2004 | 10:06 AM
billyjoe's Avatar
billyjoe
Where did you get it? Please. And what is the part number. Please. Man, this is like pulling teeth!
Explorer4wheel
Jan 13, 2017 06:53 AM
coppertales
Oct 6, 2015 10:49 AM
mech1
Aug 17, 2015 07:13 AM
billsimcox
1997 - 2003 F150
16
Mar 10, 2006 08:47 PM
banjoman
Oct 3, 2002 08:59 PM
