Calibrate Speedometer '96 Explorer
Old Oct 2, 2002 | 11:23 PM
banjoman's Avatar
banjoman
Post Calibrate Speedometer '96 Explorer
I've got a '96 Explorer 4x4. I changed the tires from the stock 225/70 to a 235/75 (also a stock size). It's a manual transmission so the shift point isn't an issue. What is the issue is the $170 ticket I got 'cause my speedo is out 10% instead of the 5% I thought it was.
Anyway, long story short, I went the local Ford dealer and the service manager told me he was prohibited from adjusting the speedometer because the larger tires would cause increased fuel consumption. He indicated I needed to change the axle ratios to fix the speedo. I'm gonna shop for a different dealer to see if I get the same story.
I think it's an electronic speedo so I don't think the $8 speedo gear described in earlier posts will work. I'm reasonably handy with a wrench and would like to fix it myself if someone could point me in the right direction. Has anyone else come across this before?
Thanks in advance.
Cheers,
Ray
Old Oct 3, 2002 | 01:55 PM
reberhardt's Avatar
reberhardt
Your '96 will take an $8.00 gear. Your VSS is located on your transfer case and is held on by one 10mm bolt. Remove it and count the teeth. Go down to your Ford parts deparment and get one with one less tooth on it. If your stock one is black, get a pink one. If it is pink, get a yellow one. If it is yellow get a white one.
When you changed your tires, you went from a 27.4" tire to a 28.9" tire which is 5.4%. If you are off by 10% now then your speedometer was off by nearly 5% to begin with. If you are certain that you are off 10% instead of 5%, then you will need to get a gear with 2 less teeth. In which case if your stock one is black, get a yellow one, if it is pink, get a white one and if it is yellow, get a wine one.
Old Oct 3, 2002 | 02:23 PM
borland's Avatar
borland
I changed the tire size on my 92' once. Replacing the gear at the transmission for the speedo is easy and only a few bucks.
But I couldn't find a local shop that had a speedo calibration service. Also, there were no highway 1 mile markers in my area that I could use to calculate my speed.
What I did was to purchase a GPS unit at Walmart. In addition to determining location, the unit had a speed function. So I was able to verify my speedo with the GPS unit. It worked great!
borland
95' XLT
Old Oct 3, 2002 | 08:27 PM
soso's Avatar
soso
>bucks.
>borland
>95' XLT
what a coolway to get a gps
Old Oct 3, 2002 | 08:59 PM
97 awd xlt blue's Avatar
97 awd xlt blue
abyars111
Oct 4, 2025 09:43 AM
Amish65F100
Apr 5, 2017 08:37 AM
Explorer4wheel
Jan 13, 2017 06:53 AM
Scotty's 52 F3
Sep 13, 2015 08:39 AM
hooptytank
Aug 25, 2015 09:05 AM
