casting numbers
Old Dec 26, 2004 | 09:03 PM
f700's Avatar
f700
casting number s
hi again , 9 has two dots under it , crank no number on the 7th weight,
but starting from the rear weight/ flywheel end the letter A ,then on the 6th weight the letters 2 T
Old Dec 26, 2004 | 09:36 PM
f700's Avatar
f700
casting number,s
hi number,s on pistons on the top of the piston , cam z13 ( under that )3m bore is about 98mm and stroke is about 90mm ( no head gaskets)
engine number is FH12337S ( aussie truck number ) cast marks on crank
like a aline on the weight that line up like a broken line running down the crank on each weight , is that a (parting line ) under the 9m5 ( date casting)
is two AA thank for all your help to would be up the creek with no paddle
i have one more motor to pick up this year it has a engine number very close to this one , FH12140S both were 391 truck motor s not looking good so far away your repile
Old Dec 27, 2004 | 07:17 AM
FFR428's Avatar
FFR428
Needsmorecoffee.
The block is a 79 date code and the 2T crank is a 360 cast iron with a 3.50 stroke. That's a pretty late casting also. I'm still not sure what bore the block is but it sounds like a 360. The best way to tell is to measure the cyl bore. 360/390/361/391 blocks have a stock 4.05 bore. If you think the engine is still in stock trim with the 2T crank then it's a 360. G.
Old Jan 5, 2005 | 04:24 AM
f700's Avatar
f700
casting number,s
hi thank you for all your help ,not what i want to hear but i think its still could be ok to rebuild i have one more motor to pick up , will wait to see what that one is my lucky it will be a 361 to it s engnie numbers are very close he say ita a 391 truck / 1967 again thank,s or your time on this member hope 2005 is go for you bye for now
olderford76
New Member Introductions
Sep 14, 2015 11:21 AM
Roger C
Apr 2, 2015 11:36 AM
1972RedNeck
Jun 1, 2012 07:17 PM
Gear Up
May 29, 2012 07:32 AM
FE 390
13
Sep 26, 2003 08:51 PM
