Rough idle, rough running
Old Apr 21, 2002 | 12:57 PM
MrRangerSir's Avatar
MrRangerSir
My 94 xlt, 2.3litre, 5 speed will hardly go down the road. i.e. went to the mall and parked. Ran smooth, no missing everything normal. Left the mall and the truck was rough running and with full accelleration it would not go faster than 65 mph. When in 5th gear, full throttle speed would desend (not enough power to maintain speed). By the time I reached home it would not idle. Changed the plugs, wires, replaced the pcv. I also noticed, while under the truck, a black burn spot {possibly a hole} on the catalatic converter, don't know if that means anything or not. The truck has 84k miles. Whats an easy way to check for vacuum leaks? Befuddled!
Old Apr 21, 2002 | 04:32 PM
55trucker's Avatar
55trucker
it sounds as tho your trucks pcm has gone into limp mode......i take it you are not seeing a check engine light?......possibly your pcm has failed......take a look at this situation...
Old Apr 21, 2002 | 05:13 PM
tjohnson's Avatar
tjohnson
start by checking your fuel pressure. sounds kinda like a fuel pump gone bad.
Old Apr 22, 2002 | 09:37 AM
Ken00's Avatar
Ken00
Pull the codes first, could also be a clogged cat.
Old Apr 22, 2002 | 06:33 PM
dono's Avatar
dono
Gone but not forgotten.
Sounds like a clogged cat.
Dono
Old Apr 22, 2002 | 07:37 PM
Ken00's Avatar
Ken00
11perry
Aug 17, 2013 02:13 PM
BigRedFordTruck
Oct 25, 2010 07:50 PM
playboy4aday
May 9, 2010 12:40 PM
n3hcp
Aug 16, 2006 07:35 PM
Fastronald
Illinois Chapter
15
Dec 10, 2004 06:55 AM
