Tach Install Question (yup, again)
Old Apr 19, 2002 | 02:12 PM
BobFlowers's Avatar
BobFlowers
OK. I've been reading on a lot of these Ford messages boards, a lot about installing tachometers into vehicles without tachs.
My question is:
If I have an '87 Ranger 4Cyl/2.3L, and the tach I got from a '88 BroncoII 6Cyl./2.9 is installed to replace to old cluster, I've been told that the tach will read double the rpm. OK, if so, then remember the "old" tach & dwell meters from yesteryear, that had the switch on them for 4cyl/6cyl/8cyl??
If it's that simple, then what circuitry (a resistor?, is so, what value) would need to be placed where, if indeed that is what needs to be done? If not, then what?
Also, the harness plug appears to be reversed, I have the factory wiring schematics, and will attempt to wire as per the diagrams, but before I go that route, I want to make sure I can get the tach to read the proper RPM.
Anybody ever do this??
Old Apr 22, 2002 | 11:25 AM
loudfords's Avatar
loudfords
I'm trying do something similar, have the factory 6 cyl tach read a V8 signal. So far I haven't been able to find anything on the web or anywhere else about it. Wouldn't it be nice if Ford had put the 4-6-8 switch in the factory tachs?
Old Apr 24, 2002 | 09:43 PM
BobFlowers's Avatar
BobFlowers
Orrrrrrrrr,
If some genius electronic wizard on this message board could let his knowledge shine???
Old Apr 25, 2002 | 01:07 PM
billabong132's Avatar
billabong132
hustler54
Electrical Systems/Wiring
Mar 30, 2014 08:29 PM
264WSM
Sep 27, 2013 04:43 PM
i0142carrera
Jan 25, 2004 05:55 PM
TallPaul
Aftermarket Products
Jun 26, 2001 02:56 PM
