pressure specs for HPOP
Old Nov 14, 2004 | 09:58 PM
00SvtLightning's Avatar
00SvtLightning
Anyone know the pressure specs for the HPOP. I hooked up my snap-on scan tool, with the 99 PSD at running temp, my readings were 460 to 490 psi at idle, fluctuating alot. At 2500 rpm i only got 1,150 psi. the readings were flucutating alot, is this the regulator or the pump its self that might be bad? Or are the readings within specs?
Old Nov 14, 2004 | 10:09 PM
psdpower's Avatar
psdpower
Can't remember exactly but I think that is a little low. Idle is supposed to be about 600 psi I think.
Old Nov 14, 2004 | 10:27 PM
mech2161's Avatar
mech2161
Cranking at 100 rpm min. it should be 500 psi that is the min pressure to enable injectors.
Old Nov 14, 2004 | 10:41 PM
00SvtLightning
I had a 96, i think it was around 800 when i was working on it but cant remember either.
Old Nov 15, 2004 | 06:27 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
It should be at least 500 at idle (around 1000 while cranking) and upwards of 2500 as you approach WOT.
I would try a IPR first since it's a lot cheaper and easier than the pump. Might also check or replace the ICP sensor since you were using a scan tool as opposed to a direct pressure reading.
Old Nov 15, 2004 | 08:13 PM
International Tech's Avatar
International Tech
How much fluctuation are you getting. Alot of fluctuating tends to be caused by aeriation of the oil.
Old Nov 15, 2004 | 09:39 PM
00SvtLightning
also had 2 DTC, exhaust control valve, i have a exhaust brake though didnt know if thats why i had that DTC? And the other was low boost. If that valve is half opened would it cause the truck to run poorly and have low boost?
Old Nov 15, 2004 | 10:07 PM
psdpower's Avatar
psdpower
Yes if your EBPV is stuck partially open your truck will run poorly and will not make much boost. What type of exhaust brake do you have?
Old Nov 15, 2004 | 10:20 PM
00SvtLightning
the brand is E braker, there is a toggle switch you have to turn on to activate it, you can only tell its working when going down hills.
Old Nov 16, 2004 | 08:48 PM
barebackjake's Avatar
barebackjake
got it 600psi idle 3000psi full load wot
sounds like ipr to me, or the sensor
Old Nov 16, 2004 | 08:57 PM
00SvtLightning
thanks, i unpluged the sensor on the head got the diff. idle. Is the ipr valve sensor right above the valve itself? If so i unpluged it and the truck died. maybe then the valve? Can they be cleaned?
Old Nov 16, 2004 | 09:24 PM
barebackjake
the ipr sensor is in the drivers side head at the front, the ipr is in the hpop pump the drivers side of the pump sticking out horizontally tward the back of the motor. if ipr is working it should die when unplugged. could be a wore out o ring in the ipr causing problem also
Old Nov 16, 2004 | 09:31 PM
00SvtLightning
ok thanks i may pull out the ipr valve and inspect it. If you unpluged it and the truck dies, you could still have a bad O ring that wouldnt show up unless disasembly?
Old Nov 16, 2004 | 09:34 PM
barebackjake
the bad ipr oring is kinda hard to pin point till its apart. how many miles??
Old Nov 16, 2004 | 09:39 PM
00SvtLightning
227,000 Its a 99 CC DRW Ive probally put 10,000 miles on since i had it.
