Upper Radiator Hose Too Long?
Old Nov 14, 2004 | 09:19 PM
Boss50's Avatar
Boss50
Can someone tell me how the upper hose should look going from the engine(300)to the radiator? Mine goes up for awhile and then back down into the radiator. The bend is above the filler cap which would mean that the bend is filled with air all the time and thats why my heater doesn't work good. So is this bend suppose to be there or do I need to trim my hose a little? Thanks
Old Nov 14, 2004 | 09:31 PM
nickmobile67's Avatar
nickmobile67
You can check my gallery for mine, but it's an efi 302, so I don't know if it will help any. The upper radiator hose shouldn't affect the heater, though.
Old Nov 14, 2004 | 09:34 PM
F150'89's Avatar
F150'89
Trim off a little until it fits right
Old Nov 15, 2004 | 01:31 AM
locknkey's Avatar
locknkey
go compare a new one from an auto parts store...that'll tell you for sure, but if your heater isn't working, its not cause of the upper rad hose.
Old Nov 15, 2004 | 07:39 PM
RR4E's Avatar
RR4E
Likely the heater isn't working because the valve is stuck shut, or the heater core is plugged. If you're worried about air in the hose, have someone sit in the truck, while it's running, and rev it to about 1200 rpm while you top off the radiator. The increased flow and pressure should allow the air to be removed.
eenyok
Feb 2, 2023 05:25 PM
annaleigh
Jan 14, 2016 09:22 PM
dtgl90vt
21
Jan 3, 2016 12:20 PM
saauvenshine
1947 and Older Ford Trucks
Oct 5, 2015 11:13 AM
TimH
Jun 28, 2003 01:57 PM
