1978 - 1996 Big Bronco
motor problem HELP!!!
Old Mar 7, 2004 | 11:12 PM
benschultz4x4's Avatar
benschultz4x4
hey guys i have a 86 ford bronco fullsize with a 302 fuel injected motor, and i think i got a bad fuel injector, i hear a whisling nose by fuel injector #1 and i give it higher rpm's and i get this loud POP nose by that injector, is there a special trick to test them? are how do i go about replaceing that one?? and thing will help guys thanks
Old Mar 7, 2004 | 11:17 PM
BroncoRoadKill's Avatar
BroncoRoadKill
You can go too a shop and heve them put it on an engine analyzer and they can turn the injectors off 1 at a time. Or find what is causing the problem.
DW2455's Avatar
DW2455
I dont know, i havent run into that problem, but maybe its just a bad o-ring around the injector, try spraying carb cleaner or ether around it while its running and see if the engine tone changes, if so then it definatly sucking air. Good luck DW
MC5C
Aug 2, 2013 07:33 PM
dmack91
Nov 14, 2012 12:56 PM
Moto52
Jan 9, 2010 08:17 PM
88fordmasonbody
May 13, 2002 05:34 PM
