Gauge Questions?????
Old Nov 14, 2004 | 07:38 PM
westpsd's Avatar
westpsd
Talking Gauge Questions?????
I just installed EGT, Boost & Trans Temp gauges in my truck. The truck ('99 F250, 7.3) is stock except for a K&N Kit and a Hypertech Programmer III. The readings I am getting on the boost is "0" at idle and easy city driving and 20" at WOT. EGT tempertures are running at 400-600 in easy city driving and up to 1050, WOT sustained for 20 seconds). Are these normal readings? I have a 14,000# 5th wheel I am going to pull on vacation this week and want to make sure all is good before starting on a 4000 mile trip.
Any feedback would be appreciated.
Old Nov 14, 2004 | 07:41 PM
mech2161's Avatar
mech2161
Readings seem normal. Keep an eagle eye on them when you hook to your trailor. Your program setting will make a big difference in the readings.
Old Nov 14, 2004 | 10:15 PM
psdpower's Avatar
psdpower
Numbers seem about right, you do have the pyro probe mounted pre-turbo, right?
Old Nov 15, 2004 | 03:42 AM
jammer1's Avatar
jammer1
I've just bought a 01 F-250,4x4, ex-cab, long bed. It has a 7.3 with auto trans. and 47,000 miles. I work construction (am on the road all the time) so I do get into some dusty areas. I do a little towing, but nothing real heavy at least not yet. I would like to get a little better mileage if possible. A little more power would be nice but it's not that important. I would like some suggestions and please be specific. I am new to this site so have pity on me.
Old Nov 15, 2004 | 05:40 AM
RubberDuck's Avatar
RubberDuck
Jammer1, First off welcome to the site. But no one will have pitty on you if you keep thread jacking. You should start your own thread. But I guess we've all done it a time or two. I would suggest a Tymar Intake, straight pipe exhaust and a tuner for the things that you seek. But Like in the start of this thread, you need gauges to monitor your truck more closely so you don't burn it up. Hope that helps.
West, sounds like you are right on to me. But if you have your truck on the highest setting, I would suggest backing it off.
RubberDuck
Old Nov 15, 2004 | 08:39 AM
rufaast's Avatar
rufaast
I have the Super Chip in mine,cobalt blue gauges, i installed pyro in the drivers side manifold, i see at 70mph , 2000rpm, 600degrees on egt, around 5-7psi of boost, this is with the 80HP chip installed. WOT not pulling a trailer, i see a spike of 27psi and settles around 25psi.
I would say numbers are normal.
Old Nov 15, 2004 | 10:05 AM
farmb0y's Avatar
farmb0y
westpsd- your numbers look normal. But your EGT's will jump hard when pulling a trailer. Might want to set your programmer on the lowest setting or even pull it out, you'll have to run it and see where you are safe with your temps. You'll sure love having the gauges though, especially when pulling a trailer. It's nice knowing how your truck is running, and not having to trust the "idiot" gauges on the dash.
doug42190
Jul 20, 2016 03:15 PM
tjmike
384
Jun 5, 2016 10:24 PM
straightexhaust
Oct 16, 2015 02:16 PM
Tugly
46
Sep 5, 2012 01:09 PM
WALJON
Feb 6, 2010 04:51 PM
