MCU system on 83 ranger...how does it work
Old Mar 18, 2002 | 06:56 PM
fordmanSLO's Avatar
fordmanSLO
I have an 83 ranger that I almost got running. Its having problems with the carb, and I want to be able to troubleshoot the MCU system, but my old chilton manual says nada? Anybody got some documentation on this, or know where to get any? Any helpful insights would by much appreciaed too. Thanks
Old Mar 19, 2002 | 06:28 PM
Ford 4 Life's Avatar
Ford 4 Life
The MICROPROCESSOR CONTROL UNIT. Oh what fun! It keeps the Air/Fuel mixture ballenced. The O2 sensor tells the MCU if the carb is running to rich or to lean so make sure that it is functioning properly. I had an 83 Ranger about 10 years ago. I took it over from my Dad. It had some serious issues. The carb was flooding, It was running rich, it needed attention. I had to take it to a auto electric shop to diagnose it. Turned out the computer was shot. After going to several auto repair shops who could not get one, I found one that did. I put the new MCU in and replaced the 02 sensor. I had the carb rebuilt at the Ford dealership. It ran perfect after that. It was a serious headache but it all worked out in the end. The computer was I think around $250.00, Ford I think charged me around 300.00 for the rebuilt carb and tuning it up.
Hope this helps. Good luck!
Old Mar 19, 2002 | 08:10 PM
fordmanSLO's Avatar
fordmanSLO
Is there any way I can bypass it, just so I can get this thing running again? I got a feeling most of the electronics are bad, because it was underwater, but I'd like to see if the motor can run at least
Old Mar 19, 2002 | 08:55 PM
Ford 4 Life
I had that option. I chose not to because the carb will not work properly, it was made to coinside with that MCU, If you bypass it you will get irregular idleing and it will not perform well(bad MPG),you may not pass DEQ. If you plan to keep the truck you might want to see if there is a different carb that can be put on that engine that does not reqire the MCU as a componant. As far as finding out if there is a different carb for that engine, a Ford dealership might know or help stear you in the right diection. I say a Ford dealership because if anyone knows about ford they would. I usually use The dealership for a diagnosis of any problems. If you plan on selling it,I would go with the first option(bypass the MCU), I think it would be cheaper. Your truck will run, just not well. I could not handle the irrregular idle. It would bother me. Then again your truck might run fine. You said yours was a 2.3L, Mine was a 2.0L, I don't beleive that would make much of a difference, but it might.
I'm not a machanic. This was just my expierience.
If you have anymore questions E-mail me. Booker63(No Email Addresses In Posts!)
Good Luck!
Old Mar 19, 2002 | 10:55 PM
fordmanSLO's Avatar
fordmanSLO
But how do I do it? just unplug it? Makes sense, I guess. I can repair it once I get it running if I know thats it. I'm not worried about the bad MPG, etc, because this is just to make sure it'll run at all, and I just want to figure out why it won't fire up by itself.
Old Apr 28, 2002 | 10:38 AM
1992 XE 4X4's Avatar
1992 XE 4X4
On my 83 that I had. I bought it with the mcu not working. I put a 2 barrel weber carb. (factory) from from a pinto. I disconnected the rest of the mcu and plugged the vacuum lines. It ran as well as a 2.3l could with an automatic. That was some years ago and I still see the truck is still on the road. Knowing how Ford likes to change parts and designs, sorry I can't give you anymore info on the pinto carb.
Old Apr 29, 2002 | 09:54 PM
nitro94's Avatar
nitro94
Those old mcu systems only control about 10% of the fuel delivery amd really don't have the ability to keep it from not running. Run bad yes but not run at all, no. Try the basics, diagnose this like a non ecu system to get it running.
Old Apr 30, 2002 | 09:14 AM
aksniper's Avatar
aksniper
montana_highboy
41
Mar 23, 2021 10:59 PM
tjmike
46
Nov 13, 2018 09:42 AM
EpicCowlick
6.7L Power Stroke Diesel
Apr 14, 2016 03:40 PM
ngng
Oct 31, 2014 09:23 PM
red91ranger
Mar 6, 2004 10:04 PM
