Sponsored by: Auxito
rusty rear end cover
Old Nov 14, 2004 | 06:58 PM
Rocky J's Avatar
Rocky J
Does anyone else have a problem with the rear pumpkin cover rusting on their F150? Mine is 2.5 years old with 40K miles and half the paint has fallen off the gear cover. The rust formed under the paint and I can pull chunks of paint off. 2wd 5.4 with 3.3 gears.
Anyway, I assume I can wire brush and paint this thing in place with something like Extend® and then sand and paint. I might remove it just to check out the inside and so I can wire brush it on the bench grinder. Are there any decent aftermarket covers available? I assume a factory replacement would rust just as quickly as this one did.
Old Nov 15, 2004 | 06:24 AM
Rocky J's Avatar
Rocky J
So, mine is an isolated case? If no one else has seen this problem, I'll just buy a new cover from the dealership.
Old Nov 15, 2004 | 07:09 AM
holland501's Avatar
holland501
I read somewhere that the rusting is due to excessive heat. Mine did thw same thing. 97 F250 4x4. I've done some fairly heavy towing a couple of times in the past, but I couldn't say if that caused it because I didn't notice it until recently.
Old Nov 15, 2004 | 07:10 PM
grafekie's Avatar
grafekie
I really think its a normal thing. Is it giving you issues? My 99 has a nice protective covering of rust on the differential, and I really think its just surface scarring, not actually a problem.
Old Nov 15, 2004 | 08:43 PM
JH6's Avatar
JH6
I like to paint it with a brush and a can of rustoleum flat black once a year.
JH
Old Nov 15, 2004 | 09:33 PM
AzBlueWolf's Avatar
AzBlueWolf
How about a chrome diff cover? http://www.fordracingparts.com/parts/part_details.asp?PartKeyField=208
or maybe an aluminum cover?
http://yourcovers.com/dc_9519.shtml
just some ideas...really dress it up!
Mark
_______________________________________
01 F150 Supercab Flareside 4x2 5.4L Auto
Deep Wedgewood Metallic and Silver
Fabtech Lift 285/75/R16 Dominator Sport A/T's
Old Nov 15, 2004 | 09:48 PM
Rocky J's Avatar
Rocky J
I like the looks of the finned aluminum covers with the drain bolt but I don't like them $150 worth. I just went out and crawled under the truck with a flashlight and mine has 12 bolts instead of 10 like the one shown. The rust isn't as bad as I thought, I might just clean and paint it in place without pulling it. But with the 'less than optimal' shifting of the truck (bought with 37K miles) and now this, I'm guessing that it might have been abused more than I first suspected. I guess I need to just pull the cover and change the fluid just so I know what it looks like in there instead of just guessing and worrying.
Thanks for helping me make up my mind. I'll post here tomorrow after I pull the cover and change the fluid.
Old Nov 15, 2004 | 09:54 PM
AzBlueWolf's Avatar
AzBlueWolf
yeah, in a perfect world...we could all afford the goodies.
Mark
____________________________________________
01 F150 Supercab Flareside XLT 4x2 5.4L Auto
Old Nov 16, 2004 | 02:14 AM
macgyvr's Avatar
macgyvr
my 2000 60k miles, was rusty...and when i started to hear a groaning noise when turning corners i changed the fluid with the reccommened synthetic fluid and cleaned the outside of the cover up and painted it with rustoleum...no problems and the groaning noise went away....
makes the heat argument sound possible...
mac 'little paint never hurts' gyvr
