Cure for the Dreaded Pinging, Knocking and Tapping Engine
Old Apr 30, 2002 | 08:41 PM
Ken00's Avatar
Ken00
Old May 3, 2002 | 12:28 AM
NightRangr1999's Avatar
NightRangr1999
[updated:LAST EDITED ON 03-May-02 AT 01:39 AM (EST)]I had for the longest time, that nasty old ping, ping, ping & tap, tap, tap noise when under a load and EVEN on level keel straight-aways my when truck hit 60 MPH + or -. You know, the sound that comes from your engine, like your valves are about to rattle off. Well, I did just about everthing I could think of, short of shooting the engine. I finally had enough and took my truck to the Ford Dealership and they took a look at it and said it need a microprocessor and a ignition coil assmebly and that it would run me about 6 hundred and some change (parts & labor). I about died, seeing that my truck is just over 3 years old, and did I mention that this occured just AFTER the 3 year warranty expired?? Anyway, the nice man at Ford did some research for me and I was able to get it fixed at no charge. Apparently a Technical Bulletin 8-80 warranty applied and then two days later, my 99 Ranger is running like it was when I got it off the showroom floor! So, for all you that think you are doomed, mention the Technical Bulletin 880 for emmissions. Technical Service Bulletins Summary
Make: FORD TRUCK
Model: RANGER
Year: 1999
Service Bulletin Number: 6884
Bulletin Sequence Number: 886
Summary Description:
CUSTOMERS MAY COMPLAIN OF AN INTERNAL LOW END NOISE THAT IS DESCRIBED AS A "DIESEL AND / OR MARBELS IN A TIN CAN RATTLE" ON VEHICLES WITH A 4.OL OVH ENGINE. *TT
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
