too slow 63
Old Nov 14, 2004 | 06:50 AM
mikeyf's Avatar
mikeyf
too slow 63
I need some advice. I have a 63 f-100 with a 233ci motor and a 3 speed manual tranny. Most of my driving is at highway speed (60mph-70mph), the motor has to turn too many rpm to keep out of everyone's way. I have a 460ci (machine work is done, needs to be put together), a 400ci (needs rebuilt), a C4, and a C6. Would you suggest using one of these combinations, finding a 302, changing rearends? My concerns are fuel economy, (could I get 15mpg from the 460), the initial, the operating cost, drivability and reliability. Thanks.
Old Nov 14, 2004 | 07:38 AM
ddavidv's Avatar
ddavidv
My first instinct is to look at your rear axle ratio (you didn't post what it is). This is the easiest solution to your problem. The automatics will all suck more gas as they have more drag than the manual. Going from a six to a 460 will also not help mileage. What you're trying to address is the rpm's you are turning at highway speeds. The slushboxes you have are both 3 speeds, so it's pretty much the same as the manual you have now. The only auto trans that will help you is something like an AOD that has a overdrive cruising gear.
I really think you are looking for a higher gear (lower numerical). Going from a 3.25 to a 2.73, for example, will lower your revs at 70 mph.
Old Nov 14, 2004 | 08:12 AM
312's Avatar
312
you may have around a 390 axle.
Old Nov 14, 2004 | 10:05 AM
oldschool63's Avatar
oldschool63
my 63 originally had a 383 rear ratio. changed it to a 350 ratio and was able to go at highway speeds at a reasonable rpm. I was going to raise it even further to a 300 ratio but i was never going to use it as a tow vehicle again either. for towing I wouldn't go with more than a 325 ratio, although I'm thinking that would still be too high. If I remember correctly, the 3:83 was the standard ratio for 63's.
Old Nov 15, 2004 | 05:25 AM
jowilker's Avatar
jowilker
Mike, Folks didn't drive pickups over 50 when yours was built, (a different time all together) Your engine is small and sounds worse than it is. As mentioned the rear ratio is in the 3.75 to 4.10 range most likely. Swapping in a 3.50 rear will help things a lot and will be the cheapest thing to do as well.
The best bang for the buck would be to go to a 4.9 or 5.0L EFI with overdrive. The larger engines have a lot more power but need more oats.
John
thesixd
Large Truck
Dec 10, 2013 04:53 AM
cdrmckinneybb63
Apr 2, 2013 10:00 AM
jamies460
May 5, 2007 03:51 AM
jamies460
Jan 16, 2007 07:59 PM
Tommy_Mike
1997 - 2003 F150
Jan 9, 2003 03:36 PM
