460 Hedman headers + true duals
Old Nov 13, 2004 | 08:09 PM
Trav460's Avatar
Trav460
i decided to go with the some headers and put true duals for better performance/mileage but im debating on flowmasters or dynomax bullets, rite now i have 3 " into flow then dual 3" out and its pretty loud so putting headers on is gona make her real loud! i did this on my old chev on a 454 with hooker headers dual glasspacks and dumped before the wheels it was louder then harleys with straight pipes!! i ended up putting flowies on it after that did make it alot quieter but with the glasspacks it was really deep. But anyways back to the ford my trucks a 97 EFI. I found hedman headers for my truck then wana do true duals both down the passenger side out behind both wheels at the back i also wana do a X pipe would a X pipe make it louder? quieter? also i rather go with bullets then flowmasters but i no its gona be to loud.. if anyone has done a similiar setup on there BB plz let me no. I was thinkin of doubling up 2 bullets on each side, should still be nice and loud rite? thanx for any replys
Old Nov 13, 2004 | 08:37 PM
351M's Avatar
351M
The X pipe will make it quieter, if you put 2 bullets per pipe then you might as well go get a couple glasspacks.
Old Nov 13, 2004 | 08:47 PM
docholiday72tx's Avatar
docholiday72tx
Im running a set of headers, flowmasters, and 2 1/2 inch pipes on my 460. I have dual pipes that run straight out the back. Mine is loud enough to sound realy good, but quiet enough not to attract the wrong type of attention.
Old Nov 13, 2004 | 09:01 PM
Saurian's Avatar
Saurian
You might go with a tunable muffler, possibly?
Those Dynomax's sound like a real winner...but I wanna be really loud so =P.
Old Nov 13, 2004 | 10:28 PM
77hiboyboy's Avatar
77hiboyboy
3 inch to hooker aero-chamber or single chamber slowmasters, if you dump the cats you will get the most sound, and depending on what muffler setup you go with I would go either H or X pipe. Chambered mufflers such as flows need a H pipe, straight through such as race bullets need an X pipe.
Old Nov 14, 2004 | 12:22 AM
f250rangerexplorer's Avatar
f250rangerexplorer
i have dual moroso spiral flows on my truck with dual 2 1/2's all the way from the manifold. should i have an x-pipe or H-pipe?
Old Nov 14, 2004 | 02:25 AM
docholiday72tx
I'm running Flowmasters on my truck with no H or X pipe. What is the advantage of having one, and which one is best for a 460 with headers, 2 1/2" pipes and 40 series flowmasters?
Old Nov 14, 2004 | 12:40 PM
Trav460's Avatar
Trav460
thanx for all the replys guys, i forgot to mention that i do have one bullet on my car its a 01 trans am i took the cats out but it still has manifolds was straight pipe but it was really raspy but the bullet in and its still nice and loud but deep tone! sounds perfect but i was thinkin with a big block with headers is gona be twice as loud. Also the truck has no cats.
Saurian - u mentioned a tunable muffler?? that would work good for my set up.. but who makes a tunable muffler??
Old Nov 14, 2004 | 09:16 PM
kevinrf250's Avatar
kevinrf250
I have L&L headers on my 1994 460 and really like them. The rest of the exhaust is 2 1/2" duals, H-pipe, no cats, and Flowmaster 50 series delta flow mufflers. I really like this setup. The L&L's are worth the money. The truck isn't overly loud when driving down the highway, but when you get on it it has a deep rumble that will turn heads(and set car alarms off). There are pictures of it here. http://community.webshots.com/user/kevinrf250 Hope this helps.
Old Nov 15, 2004 | 09:18 PM
Saurian's Avatar
Saurian
Supertrapp Tuneable Mufflers - SUP-443-2010 125.88
Diskpack's for Tuning - 9.95-26.95 depending on number and size.
Get onto Summit's website (Summitracing.com) and look in the exhaust section for muffler's and then go to Supertrapp. All you need ot look at. Disc inserts regulate sound suppression. May be more on the website too.
Big_Red_Brute
28
Sep 11, 2014 03:16 PM
choate
Jun 19, 2014 12:48 PM
ryanscott
23
Jul 3, 2013 02:30 AM
Trucklife_123
Exhaust Systems
May 17, 2013 11:12 PM
Lead_Foot
Exhaust Systems
Dec 26, 2005 10:37 PM
