460 base timing check
Old Nov 13, 2004 | 06:00 PM
shaggin1's Avatar
shaggin1
Exclamation 460 base timing check
I have a 91 1 ton crew cab 4x4. I had it smoged last week and it passed the emissions portion of the test, However, they check base timing by uncapping a plug in the wiring from the electronic fuel module. When they uncap it on mine, the truck dies and will not start. If you put the cap back on it starts. I replaced the ignition module but no change. Anybody know what else it may be?
Old Nov 13, 2004 | 09:58 PM
ATC_250SX's Avatar
ATC_250SX
can they just check it with a timing light, to see that it is at 8 Degrees BTDC?
Old Nov 14, 2004 | 12:22 AM
drewcoolness99's Avatar
drewcoolness99
don't you just disconnect it to set the base timing? not check it?
Old Nov 14, 2004 | 09:35 PM
shaggin1's Avatar
shaggin1
Yes to both. The plug is disconected to set, and check base timing. The smog shops check base timing by doing this also. However, if my engine dies when plug is removed neither can be done.
Old Nov 14, 2004 | 09:36 PM
shaggin1's Avatar
shaggin1
Yes they do use a timing light to check base timing. But the ehicle will not run with plug uncaped.
Old Nov 14, 2004 | 09:44 PM
ATC_250SX's Avatar
ATC_250SX
ok i guess my question is, can you put a timing light on it, without this "plug" uncapped?
Old Nov 15, 2004 | 08:30 PM
shaggin1's Avatar
shaggin1
Yes I can, and it timmed at 30 degrees, which is about right where it should be. But they still won't pass it (California).
Old Nov 15, 2004 | 08:43 PM
ATC_250SX's Avatar
ATC_250SX
Ohhh I see now, i didnt realize that, boy, if i tryed to get a sticker there, i think they would take my truck ant toss it in the scrap yard on me, emmisions, no way would it pass those. well i cant do much more on this topic, my books dont go above 88 on the 460. sorry. if i think of it when i go back down to school ill take a look on Alldata, and see if they give me any hints
Old Nov 16, 2004 | 08:59 AM
HardScrabble's Avatar
HardScrabble
Temporarily Deactivated
Get your hands on a book and make sure they are unplugging the right wire. I think it is near the driver side hood hinge, not sure. Run some searches, there are many threads on this. Base timing spout
Old Nov 16, 2004 | 01:42 PM
bansheemike's Avatar
bansheemike
They must be pulling the wrong plug. On my 92 it's near the brake master cylinder. Stop the engine, pull the spout plug and then re-start to set the timing.
Old Nov 18, 2004 | 06:49 PM
shaggin1's Avatar
shaggin1
Thanks, I would appreciate that.
Old Nov 19, 2004 | 01:32 PM
ATC_250SX's Avatar
ATC_250SX
well i looked on ford tech service, and couldent find anything, that helps you out, sorry about that, oh and aldaya was useless, so im at a dead end.
4wheeling79
251
Aug 24, 2011 11:17 AM
rmanTX
3.8 & 4.2L V6
Dec 6, 2004 09:23 AM
homer4.2
3.8 & 4.2L V6
Aug 28, 2004 02:58 PM
Tckhan
Jul 22, 2004 03:21 PM
handx2
13
Jun 18, 2004 12:59 PM
