Smashed valve spring
Old Nov 13, 2004 | 03:52 PM
mangohater's Avatar
mangohater
I have a 73 Bronco with a 302 that recently started running rough. Checked compression and found 0psi in #2. The rest were between 110-120psi. Pulled the valve cover and discovered the spring is squashed and the seat below the spring is mangled too. I was planning to rebuild soon since it leaks and burns too. What has happened, and is there a way to get a few more miles before I have it rebuilt?
Old Nov 14, 2004 | 09:58 PM
f1001978's Avatar
f1001978
You might have a bent valve, that will require the head be removed and the valve replaced.
7568kenny
Jul 30, 2013 01:35 PM
sruhge
Oct 29, 2012 05:07 PM
Byos
Nov 22, 2006 06:21 PM
mangohater
Nov 14, 2004 04:49 PM
