Smashed valve spring
Old Nov 13, 2004 | 03:30 PM
mangohater's Avatar
mangohater
I have a '73 Bronco with a 302. It started running rough, so I purchased a compression gauge. Found a cylinder with 0 psi. Pulled the valve cover off to have a peek and noticed the number 2 spring was very bent and the seats underneath the spring were also mangled. I wasn't quite ready for the rebuild yet. What has probably happened? Is it rebuild time, or can a get a bit more life out of it?
Old Nov 13, 2004 | 03:42 PM
'961506's Avatar
'961506
you might want to post this in the smallblock section aswell.
Old Nov 13, 2004 | 05:20 PM
Rancheroracer's Avatar
Rancheroracer
What was compression on other cylinders? Engine use oil? or otherwise ok? If so, you could put a set of springs on it. I think I'd replace that one & see if compression was ok before doing them all.
Old Nov 14, 2004 | 08:44 AM
mark a.'s Avatar
mark a.
I think your valve guide went out.
Old Nov 14, 2004 | 04:49 PM
94F150-408's Avatar
94F150-408
I would say its rebuild time, at the very least your going to have to pull the heads.
Jan 21, 2014 03:06 PM
78fordf150ranger
Jan 26, 2011 11:13 PM
89ford73
Sep 19, 2010 02:01 AM
streamin along
Jun 26, 2005 11:52 AM
mangohater
Nov 14, 2004 09:58 PM
