Headlight switch gets hot.
Old Nov 12, 2004 | 07:15 PM
Kevin F-100's Avatar
Kevin F-100
Question Headlight switch gets hot.
I have a 1980 f-250 3/4 ton 4 wheel-drive truck. The problem I am having is that if I drive it for a few hours at night with the lights on. When I get home I notice that the headlight switch is very hot. Is that normal or is there a problem that I don't know about? Any help on this would surely be appreciated.
Old Nov 12, 2004 | 07:56 PM
5_labsownus's Avatar
5_labsownus
These switchs get some age on them and dust inside and the go bad and produce resistance and heat. the plug is most likely bad from the heat. Had to replace both the first of the year!
Old Nov 12, 2004 | 10:20 PM
locknkey's Avatar
locknkey
ditto...5labsownus is correct...replace the light switch before your wiring melts.
Old Nov 13, 2004 | 09:12 AM
Kevin F-100
Thanks for the good advice. Looks like I will have to do some investigation on the light switch. thanks
Old Nov 13, 2004 | 10:01 AM
5_labsownus
The switches can be purchased at any parts store. Buy the switch and you will see how it is removed from the dash!
dudef150
Apr 6, 2016 04:14 PM
shakenbake254
Feb 19, 2016 06:43 PM
excavator
Nov 8, 2014 06:11 AM
Robrt32
Apr 30, 2014 10:00 AM
desperado_18_2000
Feb 20, 2001 05:53 PM
