Headlight and explorer mirror wiring help
Old Feb 18, 2016 | 11:09 PM
shakenbake254's Avatar
shakenbake254
I am about to redo my stock headlight wiring harness in my truck with bigger wire and relays. While I am doing this I plan to install a 1st gen ford explorer review mirror in my rig. The problem I am having is how to wire the mirror in. It automatically turns your headlights on and off. The mirror has 4 main wires:
White/Pink: To headlight and running lights.
Pink/Yellow: Hot in start/run only.
Orange/White: Constant 12V power.
Black: Ground.
So should I splice the white/pink wire into the wire that goes from the headlight switch to the dimmer switch and to the wire that goes from the headlight switch to the running light relay?
My second question is where do I splice into to get power only in start/run?
BTW the truck is a 1986 f250 6.9L
Old Feb 19, 2016 | 09:15 AM
FuzzFace2's Avatar
FuzzFace2
LMC makes a "bolt in kit" relay setup so there is no reason why you need heavier wiring. The stock truck wiring is only used as a switching wire for the relays.
http://www.lmctruck.com/icatalog/fd/full.aspx?Page=78
As for the mirror wiring I can't help sorry
Dave ----
Old Feb 19, 2016 | 06:43 PM
ctubutis's Avatar
ctubutis
Dave, LMC doesn't *make* anything, they are just a reseller of mostly foreign-made products.
TexasGuy001
Aug 16, 2023 10:53 PM
Festus Hagen
Aug 2, 2010 12:56 AM
jrfateranger
1983 - 2012 Ranger & B-Series
Nov 8, 2007 09:58 PM
slpin
Oct 6, 2006 01:43 PM
