63,000 mile maintenance
Old Nov 12, 2004 | 08:55 AM
Bluebauer01's Avatar
Bluebauer01
This summer before I joined the forum, I thought I found a post that list the service that is performed at the dealer for the 63,000 mile service on my 2001 EB. The post indicated that you could have these services performed at various specialty shops (transmission fluid service, etc.) along with some jobs you could perform yourself and save money. Being a new user, I used up my search limit trying to locate. Can anyone help with details?
Thanks in advance
Old Nov 12, 2004 | 10:49 AM
Aftrmidnite's Avatar
Aftrmidnite
From Scheduled Maintenance Guide, Ford P/n 1L3J-19T200-AC 60,000 Miles: Change engine oil & filter; inspect brakes, entire system; inspect coolant system & hoses; inspect exhaust system & heat shields; inspect steering linkage, ball joints, drive shaft; inspect tires for wear & rotate; replace engine air filter; replace fuel filter; replace cabin air filter (if equiped); Inspect assessory drive (fan) belt; change auto-transmission fluid & filter; inspect and lube ball joints; lubricate 4X2 wheel bearings, replace grease seals, and adjust bearings; inspect and lubricate steering linkage. 65,000 Miles: Change engine oil & filter; inspect tires for wear, recommend rotation. If your coolant system wasn't flushed and filled at 45,000 its way overdue. Would recommend buying the Maintenance Guide if there isn't one with your owners guide.
tjc transport
Jan 2, 2015 06:54 PM
abnjim6
Modular V10 (6.8l)
Aug 8, 2012 09:16 PM
WhiteLight
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jun 11, 2005 09:17 PM
02superstroker
Jun 12, 2003 08:36 PM
ivolley
Aug 17, 2001 02:06 AM
