Gauges
Old Nov 11, 2004 | 01:14 PM
fmc400's Avatar
fmc400
MSEE
Gauges
So I'm wanting to put on gauges for temp, oil pressure and probably vacuum on my 400, and haven't done this before. I'm looking at mecanical sunpro gauges. Do they actually run oil\water\vacuum lines up to the gauge from the engine? Are there any special fittings for the 400 that I need to look for? Any help is appreciated.
Thanks!
Old Nov 11, 2004 | 02:00 PM
74 F100 351m's Avatar
74 F100 351m
If you buy it in kit it will have all the fitings that you need. And it will have instutions sheet with it.
Old Nov 11, 2004 | 03:46 PM
fmc400's Avatar
fmc400
MSEE
What are the differences between electrical and mechanical gauges? Which is better?
Old Nov 11, 2004 | 03:52 PM
74 F100 351m
mechanical are the only way to go. It is a alot more accert, in my opin. And your not depending on a sencer or a sending unit.
Old Nov 12, 2004 | 01:22 AM
Torque1st's Avatar
Torque1st
Posting Legend
The mechanical gauges will have an oil line and vacuum lines from the engine. While the vacuum line is not a problem the oil line can leak or burst and flood the interior with hot oil. Sometimes they burst outside the cab and you never know until the engine blows. Go with electrical gauges. They can be just as accurate and they are a lot safer.
Old Nov 12, 2004 | 02:10 AM
Colo79Ford's Avatar
Colo79Ford
I run all mechanical aftermarket guages, and i say they are the way to go. I mean, if your line to the il guage broke....anywhere....and you were not getting any pressure reading on the guage....that would be an pretty obvious you had a problem, waiting till, or not noticing until the engine blew would be pure neglect and thick headed, if youre anything like me, im sure youll check the guages regularly while driving, aswell as at start up, about halfway thru the drive, and shut down...just an opinion. Why trust the electronics to do something you can do yourself? My oil pressure line ran right off the stock fitting for the stock one, i just put on a different fitting, and disconnected the sending unit. If you were running a engine coolant temp setup, it would be a little more difficult. But yeah, go mechanical. If you need a place to put them, you can build a plate for them, and dash mount them, or do what i did, and build a center console forthem (if its an automatic) if its manual, or 4x4, make sure to leave the appropriate space in the top of the console to allow full movement of the sticks..
--JB
Old Nov 12, 2004 | 06:07 AM
Torque1st's Avatar
Torque1st
Posting Legend
Blowing hot oil all over yourself is not fun. It alerts you to a problem pretty fast but second and third degree burns are not pretty, nor is the mess. The accident caused by a hot oil bath can ruin your day also. I have seen several instances where an oil line blew outside the cab and the engine was gone in between those "frequent" gauge readings. It only takes a few seconds of "neglect" since the engine will hold pressure until the oil is gone. A mechanical gage is a few bucks cheaper, -but a few dollars against a blown engine or severe burns is worth it.
Old Nov 12, 2004 | 12:20 PM
fmc400's Avatar
fmc400
MSEE
Are mechanical guages really that accurate? My oil pressure on that thing isn't really something to be proud of, and then it has to run through a small tube a few feet in length up to the dash. Does it really maintain the right reading?
Old Nov 12, 2004 | 03:09 PM
unreng's Avatar
unreng
Arrow mechanical
fmc,
What're the purposes of the additional gauges? Are they to keep track of the engine condition or as comparisons to the stock gauges? Is the engine an investment (rebuilt) or is it transportation (stock)? Mechanical gauges (direct measurement) are generally more accurate than electrical gauges (electrical sensor). If there's a lot of money in the engine, I'd recommend mechanical (AutoMeter). If you're worried about oil leakage, try the steel-braided line. The appropriate fittings are usually included with a gauge.
Chris
Old Nov 12, 2004 | 03:33 PM
fmc400's Avatar
fmc400
MSEE
Thanks so far for the help.
The gauges are meant to replace my row of idiot lights. One reason is I'd like to monitor things better; additionally I might be putting in a new oil pump soon and I'd like to keep track of the pressure. I don't need super accurate readings, but within a few PSI would be nice (unless that's asking too much of electrical gauges. I don't know how accurate they are).
It's an old motor, not much money in it. Gets me around town on its seven cylinders.
Old Nov 12, 2004 | 04:38 PM
74 F100 351m
Talking about seven cylinders, One time I was changing spark pluges and put the passger side on and wires put the drive side pluges in not the wires and stated the truck it ran like junk till I seen the wires and turned it off. So mine has ran on 4 cylinders. True story.
Old Nov 12, 2004 | 05:59 PM
fmc400's Avatar
fmc400
MSEE
Haha wow. Burnt up exhaust valve for me. Hope to pull the heads soon.
Old Nov 12, 2004 | 07:18 PM
74 F100 351m
My stepson's 400 had two intake valves that were worn out into the cast of the heads, both of the heads are trash. I just happen to have a nother set off of a builder. runs good now.
Old Nov 12, 2004 | 10:54 PM
good 'ol ford's Avatar
good 'ol ford
arent the stock gauges on these trucks electronic. so wouldnt it just be eaiser to stay with the same sort of setup. and how inaccurate are the electronic gauges. im wondering cuz i was planning on putting a new gauge cluster in my 77.
Old Nov 12, 2004 | 11:07 PM
74 F100 351m
If you are talking about 2000.00 motor a set of 40.00 gages is cheap insurance. I have gage that are all over inside the truck, but there is 5500.00 under the hood.
