Manual to Automatic
Old Nov 11, 2004 | 09:15 AM
rmalottwtes30's Avatar
rmalottwtes30
Manual to Automatic
How hard is it to change my truck from manual to automatic, its a ford f100 1980 has a 351m, would it be hard, how much should I expect to pay. and what things would I need
Old Nov 12, 2004 | 12:44 AM
mustange70's Avatar
mustange70
It involves some work. You need a peddle assembly, clutch linkage, of course the tranny, clutch & flywheel, proper bellhousing (if you get a trranny from a truck with a different type of motor) the center floor plan piece, and a driveshaft as well. You can expect to pay anywhere from a couple hundred to 5 or 6 hundred depending on how many new parts ou get and how greedy the wreckers are.
Old Nov 12, 2004 | 07:48 PM
8 Lugs's Avatar
8 Lugs
With a project like this, your best bet is to find an identical truck with the automatic transmission and buy it!
Park it next to yours and commence trans swapping.
It's a bit of work, but worth it!!!
Steve G.
Old Nov 12, 2004 | 08:07 PM
motorheadmach1's Avatar
motorheadmach1
dont forget about the flywheel, sure does suck when you cant bolt the torque convertor in because you never swaped the flex plate
Old Nov 12, 2004 | 08:51 PM
mustange70's Avatar
mustange70
My bad, i got it mixed up, but like 8 lugs said, it easiest to get a donor truck and swap parts.
kc7smo
Offroad & 4x4
35
Jul 8, 2024 03:18 PM
cpoer
Jan 28, 2012 09:26 AM
Maverick1978
1983 - 2012 Ranger & B-Series
Dec 25, 2011 07:02 PM
79outlawf150
13
Jun 18, 2010 07:14 AM
bronco2man
Bronco II
Mar 30, 2005 10:23 PM
