How hard would an auto to manual transmission swap be in a 1990 ranger 2.9 4x4?
on my ranger, with a whole spare ranger for parts, 1 day for the swap, another day to do all the @#$%^& other parts. Took almost 5 hours to get the clutch pedal out and in the other one (probably the hardest thing on the entire process). Drive shaft will probably need to be cut, but that is 1 day and about $150 USD.
probably easier to get a performance slush box instead.
But shouldn't have to get a different driveshaft... the Automatic and FM146/M5OD use the same length drveshaft.
For my own swap from an FM145 manual to M5OD...
M5OD $115 (all used parts from junkyard)
Shifter rebuild kit $15 NEW
Automatic driveshaft (3" shorter) $26
4.0 Flywheel $40 NEW
Clutch kit $90 NEW
Clutch Slave $40 NEW
4.0 engine spacer plate $10
I'll lengthen the front driveshaft myself and fabricate my own linkage system for the transfer case. I want to keep the 1350 transfer case rather than buy another 1354.
Josh
for clarification: Parts ranger with blown engine / thrashed body $200. new flywheel/clutch assy $100. Clutch hose assy custom length and fittings $100. since the parts ranger was a stretch 4 wd and used cardigans, neither driveshaft interchanged. I believe the manual box is longer by 3 inches than a A4LD. sold parts ranger to junker netted $200 cash, after removing $200 in pieces parts to fix my ranger.
flip the cross member for the tranny, new mount. Pre 84 or diesels use an external slave assy. Priceless.
In my applicaton... single cab, long bed FM145 rear driveshaft is 55" long. A4LD/FM146 driveshaft is 52" long.
Josh
