4wd test
Old Nov 10, 2004 | 09:30 PM
Geof's Avatar
Geof
4wd test
I would like to test my 4wd on my Ranger 1999. This truck have a electrical transfert case. Yesterday I tried little test on ice in a little slope. I put it on high 4wd and I did two test. First one I place the truck to have front wheels on the top of the hill and not on the ice. At this moment rear wheels slide. The second test is the invert situation. I placed rear wheels on top and the front one on the ice. The rear one seem already sliding. Is it normal ? For the second test I should hope the front slide because it is one ice. I would like to know if it possible I have problem with automatic hub lock.
Thank you
Old Nov 11, 2004 | 04:00 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
On dry pavement and at low speed, engage 4WD and turn about as tight as you would when negotiating a corner on a residential street. If it "bucks", then 4WD is working.
Old Nov 11, 2004 | 06:41 AM
Geof's Avatar
Geof
I will test it
Ok I will test that, But what do you want to say with "buck".
Old Nov 11, 2004 | 11:08 AM
CowboyBilly9Mile
The truck will lurch and jerk since each axle will be operating on a different turning radius. If 4WD is working and you are turning on dry pavement, you will feel it.
Old Nov 11, 2004 | 11:20 PM
Higgin's Avatar
Higgin
Yeahno good way to really explain the "bucking", but if it does it, you'll know it. If it does nothing, and turns like normal, the 4wd probably dosen't work.
Old Nov 12, 2004 | 08:13 PM
Geof's Avatar
Geof
I did the test in a underground parking but I didn't hear or feel anything. I stop the truck, I put it in low range ( electrical switch) a beging to go forward an I turn to maximum I can. At this moment the truck run normally without any sound
It seem is not working correctly. What is the problem. I have a other little problem with this truck. I have difficulty to change the position of air blower in the truck. (To push air un windsheeld on on feet). A person tell it have a problem of this type with is F250. The person have this problem and a problem with automatic lock. The relation between the problem seem to be a vacum pump who engage the lock. Can it be my problem?
Thank you
Old Nov 12, 2004 | 08:24 PM
Ken00's Avatar
Ken00
The 4wd and the air flow are both controled by vacuum, I would start looking for a vacuum leak.
Old Nov 14, 2004 | 10:12 AM
Geof's Avatar
Geof
If someone have information about that? (circuit, location etc) I locked in Haynes manual an I didn't find any thing about the vacuum pump.
Old Nov 14, 2004 | 12:03 PM
CowboyBilly9Mile
You're not gonna find a vacuum pump on the Ranger. Was the F-250 by chance a diesel?
Anyway, start at either one of the hubs, at the firewall, or on the engine (#1 choice) and find a vacuum line. Follow it around looking for a disconnected fitting(s), lose connection(s), or damaged hose(s). Simply look at all hoses. You can also test for vacuum at the hubs. I'm not sure if the hubs need vacuum to be engaged or disenaged but my guess would be vacuum is needed to engage. You can test for this with the engine running, 4WD engaged (then disengaged), and just pull a line and see if there is vacuum. Place your finger over the end of the hose to test.
