1992 F250 headlight chime
Coincidentally, I have a picture, and my dash is off. Imagine that.
In the below picture, if you look immediately to the left of the shifter, towards the gas pedal, you'll see a thing hanging down. That is the headlight, door chime, and seat belt chime/buzzer. While it is one unit plugged in a socket, its actually two buzzers in one shell.
Glad you're humored and you're welcome for the pictures. But I took it out for other reasons, it was just coincidence about the timing.
And here is the main screen as the linux PC boots up (Yes, in the above picture I was playing with XP Pro, but dumped it almost immediately). The monitor is a 13" LCD touchscreen providing 1024x768 resolution, which is fantastic for on-the-fly map viewing
Large buttons, left to right:
Top row: Radio, CD/DVD player, MP3 playing
Second row: Climate Control, Body Control, Engine Monitoring
Third row: Blank, blank, blank.
Now you may be amused
I have the cad design for the new emblems, which will go on last of course.
"Frankenford F350"
thanks for the feedback on the site, its been a fun project thus far.
The sad thing is I've not finished the dash yet, and have been driving around with it missing.
"Frankenford F350"
ok I got under the dash and found the conmector but NO buzzer I guess the original owner removed it. I called some local parts houses not expecting them to have it ( they didn't) so I called three local dealers one was clueless and the other two didn't have it . One place told me they needed a part # but I dont even have the original part !!! Any tips?
You're welcome for the info, not a problem at all.
And thanks everyone for the positive feedback. To avoid being annoying, I generally only post some pictures here, randomly, etc. If you want to follow the project...
http://www.midimonkey.com/~frederic/index.html
While you've seen some dash and electronics stuff, more has occurred. Homemade "superbumper", a fabricated dual-throttle body adaptor, which eventually will be fed by two turbos, which in turn should make the 500ish cid stroker I'm building that much more fun
And yes, I know this is a truck, not a race car!
