Coolant Change
Old Nov 10, 2004 | 05:35 AM
RBRADBURY9753's Avatar
RBRADBURY9753
Coolant Change
2000 X, 4X4, V10
It's time to have the coolant changed in my X. Is there any special procedure I should know about, or is it just drain, flush and fill? What is the best way to flush out the system, and what type of coolant is recommended for the change?
Thanks in advance.
Robert
Old Nov 15, 2004 | 05:22 AM
RBRADBURY9753
Anyone??????????
Old Nov 15, 2004 | 05:44 AM
Monsta's Avatar
Monsta
Sit. Stay.
Just drain, flush and fill. Use a kit from Wal-Mart if you like.
Coolant is any coolant that meets Ford ESE-M97B44-A. Do not use Extended Life (Orange) coolant.
There is a drain **** for the radiator on the bottom of the radiator.
Old Nov 15, 2004 | 05:46 AM
RBRADBURY9753
Thanks Monsta
Robert
Old Nov 15, 2004 | 01:40 PM
koconno2's Avatar
koconno2
Try to flush the whole system including the auxiliary heater also. The length of heater line back and the aux heater core will hold about a gallon.
NOTE: If you live in cold climate regions this would be a good time to install a block heater. I installed one but it's not required in my area. My vehicle is out side all the time and it's nice to have a fast warm up when it's 15 degrees.
freefam
Feb 14, 2022 01:40 PM
pickle40
Feb 7, 2015 08:19 PM
makthenif
3.8 & 4.2L V6
Sep 27, 2006 04:12 PM
k2lee
Sep 30, 2004 10:19 AM
kev_89_f150
Feb 10, 2003 04:57 PM
