ABS control module on 94 E350
Old Nov 9, 2004 | 09:26 PM
pbrooks259's Avatar
pbrooks259
Dealer says need ABS control module on my 94 E350 7.5L 4EOD? trans.--ABS light on, and dealer did diagnostics. Where can I get the one on mine, oe# F4UA-2C219CF, at a reasonable cost?, not at $277 from the dealer. The only one I've seen on-line is one that cross references with oe# 3FUF-2C018AB (RABS, SRW). Also have seen oe# 6FUA-2C219CA (4WABS, SRW). I'm pretty sure I have RABS, and of course SRW. Any ideas on where I can get the right ABS control module at the right place? Have checked Rock Auto, Express Auto, etc.
Also, any ideas on where to get the brake fluid pressure sending unit (I think)mounted vertically at the end of the master cyl.? Mine's leaking up through the unit.
Thanks.
Paul
Old Nov 14, 2014 | 04:19 PM
Andy1602's Avatar
Andy1602
Mine is so called 4 wheel ABS
Check to see if you have 4 wheel ABS or just rear wheel ABS. If it is 4 wheel ABS it will you will have a ABS pump under the cab right under the drivers seat and the control module in on the fuel pump bracket. That is what I have and I can't find whats wrong with mine yet. Broke my hand in car wreck and it it got cold so I can't work on mine for three months. Doctors orders. If you have to rear wheel type check the sensor on the rear axle. It should check out about 1500 ohms.
Hope that helps. Andy
Old Nov 15, 2014 | 07:33 AM
Wildman25's Avatar
Wildman25
Been a lot of posts on ABS units lately............
Read this link, if your comfortable with the results, which I did this on my '92 E350 cube van, then fine.
After repairing, bleeding, bleeding and more bleeding the brake line, and the ABS light on, I went that root, now the ABS light comes on, and goes off, I don't know of anyone that has the ABS code reader, that can clear the stored codes in the control unit, so I'm fine with the results.
And, yes, I've read the posts about the 8500# RV...........Mine is a 9600# cube van, plus sometime an added 2500# materials, and I don't have a problem. Yes, I can drive my 3600# MJ and stop on a dime, but a cube van (RV) is not going to happen, and you Drive accordingly to the weight your pushing down the road.
Of course...........try to tell that the the dummy that pulls out in front of you in their mini cars, that you have 2 extra car lengths if front of you for a reason..........
pbrooks259 - The dealer is going to tell you that, they must do things by the book, for warranty work, and as per FSM's, But........I don't think your '94 is still under warranty, unless you have the "extended warranty"
You wrote - "Also, any ideas on where to get the brake fluid pressure sending unit (I think)mounted vertically at the end of the master cyl.? Mine's leaking up through the unit."
The '94 and '92 E350 I have don't have anything at the end of the master cyl, the pressure sending unit is mounted on the disputation "T", under the master cyl, on the brake lines.
If you need one, junk yard, or PM me, I'm parting out a '94 E350.
fordguy4life
Aerostar
23
Dec 2, 2025 09:20 PM
7.5GasHog
32
Mar 5, 2018 03:45 PM
lmarkie
1997 - 2003 F150
Jun 9, 2017 12:52 AM
Longshot
1997 - 2003 F150
Sep 14, 2016 07:08 PM
fiftyfordfloored
1997 - 2003 F150
Oct 12, 2012 02:10 PM
