Headlights angle
Old Nov 9, 2004 | 08:43 PM
hinten's Avatar
hinten
Headlights angle
Does anyone know if there is an easy way to change the level of the headlights beam?
After I raised the front of my F150 my headlights appear to be aiming to high and I don't want to take it it for such a minor issue.
Old Nov 9, 2004 | 09:16 PM
asinatra's Avatar
asinatra
4mm (i think) screw/bolt thats on the top middle of the headlamp underneath te hood
Old Nov 10, 2004 | 11:21 AM
hinten's Avatar
hinten
Thanks, I'll have to try that tonight.
Old Nov 10, 2004 | 03:35 PM
BlkButy's Avatar
BlkButy
After my Leveling kit and body lift I had the dealership use a special tool to realign my headlights - no charge!
I must have been making TONS of people mad - I got the 1 finger wave alot LOL!
Old Nov 11, 2004 | 12:48 PM
hinten's Avatar
hinten
I found the screw but it didn't move the light at all.
I guess I'll have to take it in and get it done.
Old Nov 14, 2004 | 08:05 PM
04truebluescab's Avatar
04truebluescab
Adjusting lights
Hey all,
I just adjusted my lights down, since I added the 2" DMJ lowering shackles, I was getting some #1 finger too.
4mm bolt on top of light housing has to be turned one complete turn clockwise.
Yes, clockwise is down. The owners manuel is wrong.
Mark top of screw with a sharpie so you can keep track of turns.
Hope this helps.
Truck on!
Old Nov 14, 2004 | 08:10 PM
hinten's Avatar
hinten
Would anyone mind posting a pic of which bolt we are talking about?
Old Nov 14, 2004 | 08:24 PM
04truebluescab
Thumbs up
I do not have a pic but, open hood, look at headlight assemble from top. In the center and backside of assemble is a small screw with a hex or nut end. Remember this is a small threaded screw about the diameter of the radio antennna. Park facing a block wall, about 8 feet away at night, this will help set each light level or the same.
Hope this helps.
Truck on!
gtmustang00
1983 - 2012 Ranger & B-Series
Mar 18, 2013 07:35 PM
nevi325
Jan 27, 2012 09:52 AM
edub32
Jun 12, 2005 05:56 PM
bad ranger
Mar 18, 2004 01:38 AM
rogue69
Electrical Systems/Wiring
Jun 6, 2003 04:18 PM
