Sponsored by: Real Truck
question on headlights
Old Jan 25, 2012 | 02:04 PM
nevi325's Avatar
nevi325
my superduty has the glass headlights with the plastic housing and i just purchased the 2004 headlights but there is no bucket with them, i am curious if the plastic headlights will fit in the glass headlight bucket.
any help will be greatly appreciated,
Thanks guys
Old Jan 25, 2012 | 08:32 PM
nevi325's Avatar
nevi325
no one has ever tried this with the work truck front end?
Old Jan 25, 2012 | 09:41 PM
cbzdel's Avatar
cbzdel
I dont really get your question. Are you wanting to put the plastic headlight housing onto you XL model? If this is the question yes it works, I bought a set of plastic housing on ebay and installed them onto my XL, you just have to remove all of the old parts.
Old Jan 25, 2012 | 11:10 PM
nevi325's Avatar
nevi325
yes that is what i am trying to do, my headlights do not have the metal clips that are needed, do i need to purchase these? and thank you for your reply
Old Jan 26, 2012 | 12:05 AM
2002 F350V10's Avatar
2002 F350V10
The jeweled headlights are an easy swap fron the sealed beams. They actually mount totally different on the header panel, in different holes already there. The common mistake is to buy used headlights without the mounting hardware. I did the swap twice on 2 separate trucks. The one time I obtained everything still mounted on a header panel, the other time the headlights were loose without the mounting hardware, and while walking through a pick a part yard, I found a wrecked superduty and took the mounting hardware off the broken lights.
If you are just missing the metal clips on the back of the adjusters, if you remove the entire header panel, you can substitute small snap rings stacked up for a tight fit.
Old Jan 26, 2012 | 08:10 AM
Snowseeker's Avatar
Snowseeker
So the sealed beam work truck header panel is the same as the plastic lens headlight header panels? Curious because I am looking for a 05-07 head panel to do my 02-06 conversion.
Old Jan 26, 2012 | 10:27 AM
cbzdel's Avatar
cbzdel
On my 05 the plastic headlights mounted in the same location as the XL headlights, I just had to fully gut the header pannel of all the old headlight buckets and clips and such to get room for the swap.
On my 05 the XL headlight trim ring mounted with 2 screws at the top under the hood, and 2 screws between the bumper and blinker. These came screws mount the plastic headlights. I paid something like $110 for my harley style headlights, everyone says its the best money spent to date. I threw some DDM tuning HIDs in there as well, and let me tell you I can see
Old Jan 27, 2012 | 09:52 AM
nevi325's Avatar
nevi325
ok, i did the swap yesterday, very simple. just like you guys said, only thing i was lacking was the metal retainer clips, can you believe the dealer wants 10$ each. as of now i have one on each side until i get around to getting more.
now the reason i swapped these is because the glass lights were so dim, now that i did the swap i am having the same problem, it is like my daytime running lights are my headlights, when i turn the headlight switch they barely get any brighter. in oirder to see anything i have to drive with my highbeams on. any ideas?
scottddove
2009 - 2014 F150
Oct 15, 2017 07:00 PM
ttoptom1
2009 - 2014 F150
Mar 6, 2017 10:11 AM
ididntdoit99
1997 - 2003 F150
Jan 4, 2008 09:07 PM
Fordfrog206
1997 - 2003 F150
Jan 6, 2007 09:10 AM
eigenvector
1983 - 2012 Ranger & B-Series
Mar 26, 2004 12:30 AM
