Bronco II Ford Bronco II
Wiring Diagram
Old Nov 9, 2004 | 02:09 PM
Bronco2Nic's Avatar
Bronco2Nic
Wiring Diagram
I've finally got my engine back in and I'm needing a wiring diagram and mabey some pictures of the wireing harness. I'm runnind out of places to connect wires. I'll try to expand on my request in a while I don't have any time right now. Thanks for any help.
Nic
Old Nov 9, 2004 | 02:11 PM
mrshorty's Avatar
mrshorty
It probably won't answer all of your questions, but you can find wiring diagrams in the vehicle repair guides at www.autozone.com They are the same diagrams Chilton's uses.
Can't speak for libraries in BC, but around here, libraries often carry professional edition manuals (Mitchell, Motor, Chiltons professional) that will have better wiring diagrams.
Old Nov 9, 2004 | 06:25 PM
Bronco2Nic's Avatar
Bronco2Nic
While I'm hooking up my engine I'm starting to run out of places to put plugs. I have a bunch of plugs left but nowhere to put them. If somebody could email me some pictures or tell me where I could find a good wiring diagram. Thanks for any help.
Old Nov 9, 2004 | 07:48 PM
Ken00's Avatar
Ken00
Have you checked ebay or helminc.com for the diagrams?
Old Nov 9, 2004 | 08:16 PM
mouse777's Avatar
mouse777
I like to use the main library. The smaller ones usually don't have as good of a selection. 10 cents a copy here. Good Luck.
Old Nov 9, 2004 | 08:34 PM
plilikoi's Avatar
plilikoi
Nic
That's the way it should be. Seriously.
I was a bit disconcerted by this at first, but there are several extra connectors in the wiring harness tucked alongside the top of the driver's side of the engine bay.
Old Nov 9, 2004 | 11:05 PM
RomerB2's Avatar
RomerB2
Like mouse777 said, go to the library, that's going to be your best source.
Old Nov 10, 2004 | 01:39 AM
johnyaya's Avatar
johnyaya
Wiring diagrams
I've got Ford wiring diagrams for 88 and 89 (unfortunately, my Bronco II is an 86). They're about 30 pages of 11" x 17" front and back for each year. Every connector is shown. I can scan them but that will take awhile (maybe by this weekend). And if I scan them, I will need a place to send them to.
Let me know if you're interested.
Johny
Old Nov 10, 2004 | 06:56 PM
Ken00's Avatar
Ken00
His is an 85, not sure how much they have in common.
Old Nov 12, 2004 | 02:08 PM
Bronco2Nic's Avatar
Bronco2Nic
Well I got it running but there is a small problem with it. When I hook up a battery it sparks meaning that something is drawing power I made sure everything was off and I tried it again. It still happened. I fired I the engine and after a while it was running smoothly. When I tried to shut it off I found out what was drawing power. I took the key out and the engine was still running. If anyone could help me solve that problem that would be a big help. Thanks.
Old Nov 12, 2004 | 02:57 PM
RomerB2's Avatar
RomerB2
You have something wired wrong, when you turn the key off, it's supposed to break an electrical contact, thus shutting down the engine.
nic's59
18
Jun 2, 2020 01:07 AM
Bronco2Nic
General Automotive Discussion
May 3, 2005 03:34 PM
Bronco2Nic
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 16, 2004 04:29 AM
Bronco2Nic
Aug 6, 2004 09:35 PM
Bronco2Nic
Bronco II
Feb 7, 2004 06:05 PM
