Sponsored by: Real Truck
squeak from front during turning
Old Nov 8, 2004 | 08:33 PM
Gwilkrrs's Avatar
Gwilkrrs
greases frontend, it still didnt help.
power steering fluid full
squeakes when you turn the wheel either way
wife turned wheel while i watched, and it looks to be coming from the pitman arm bolt. shall i just rub greese on it? is it normal?
Old Nov 9, 2004 | 05:06 AM
slc10844's Avatar
slc10844
If you put your hand on the componets, i.e. pitman arm, tie rod end, ball joint, etc, while someone turns the steering wheel back and forth, you will feel the vibration on the squeaky part. If it squeaks, it probably needs replacing.
Old Nov 9, 2004 | 06:38 AM
LilBlackCoupe's Avatar
LilBlackCoupe
To confirm the location, spray the joint that you think it is with some penetrating oil and it will change the sound or go away. It is only temporary tho.
Old Nov 9, 2004 | 08:08 PM
Gwilkrrs's Avatar
Gwilkrrs
thanks, ill try that. i crammed greaese with the gun around the nut that bolts the pit man arm to pump and it didnt help. could it be the steering dampner? ill try to have a friend help.
maybe tire man will look, while its in for tires tommorow
Old Nov 10, 2004 | 05:19 PM
Gwilkrrs's Avatar
Gwilkrrs
tireman saa]id ford has a tsb on this problem. anyone else hear of this. he said its problebe in the tie rod to the
HighRiskJob
1997 - 2003 F150
Sep 16, 2014 09:22 AM
AkF250HD
Aug 7, 2013 06:31 PM
WickedSharp
Jan 13, 2011 09:10 PM
spdmpo
13
May 28, 2010 10:17 PM
BMLocal175
2004 - 2008 F150
May 8, 2007 01:51 PM
