Mileage
Old Jun 19, 2002 | 08:40 PM
slayerboy's Avatar
slayerboy
Mileage
this may sound stupid, but how do you determine the MPG you are getting?
Old Jun 19, 2002 | 08:43 PM
fiend's Avatar
fiend
Mileage
Take the amount of miles you drove and divide it by how many gallons you filled your tank up with. Say you drove 500 miles and filled your tank up with 10 gallons you get 50 mpg.
Old Jun 20, 2002 | 02:14 PM
slayerboy's Avatar
slayerboy
Mileage
Thanks!
Old Jun 20, 2002 | 07:17 PM
bubbernator's Avatar
bubbernator
Mileage
It also helps to use the same pump at the same gas station when filling up. Some pumps click off near full, some start spilling gas before they shut off. If you use the same pump two or three times in a row you'll get a more accurate number than if you fill up at three different stations.
CB
Old Jun 22, 2002 | 11:40 PM
slayerboy's Avatar
slayerboy
Mileage
I usually do try to stick with the same station, or at least the same brand if I can't get to that station (which is on my way home from work, but out of the way on my way to work). I'm thinking I might up to 89 instead of 87 oct. For some reason the engine hesitates when I shift. It did it in my Hyundai Accent too when I had it, so I'm thinking it's the octane. It's just that 87 is considerably cheaper than 89.
Anyone got any ideas or suggestions?
Old Jun 23, 2002 | 12:00 AM
bkarr2000's Avatar
bkarr2000
Mileage
I used to use 87 octane all the time, but then I switched to 89 since I got the K&N filter and new exhaust and my gas mileage has stayed the same, if not even gotten a little better. It provides a little more power too. I tried the 93 octane before and it produces more noticeable power, but as you know, the price is outrageous!
Old Jun 23, 2002 | 12:14 AM
Rand's Avatar
Rand
Mileage
how does 93 octane produce more power? it burns slower
which is good for advanced timing with mods like Supercharger etc
I'm curious why everyone seems to think it really boost mileage and power (reading other forums too).
Rand
Old Jun 23, 2002 | 09:21 PM
bkarr2000's Avatar
bkarr2000
Mileage
The 93 octane doesn't boost a major amount of power, but if I am cruising along at 50 mph and punch the throttle, I'm up to 80 before I know it.
Old Jun 24, 2002 | 10:05 PM
Sawbones25's Avatar
Sawbones25
Mileage
