Leaky rear window
Old Jun 24, 2002 | 03:23 PM
formermustang's Avatar
formermustang
Leaky rear window
My 98 XLT recently started leakin at the rear window. I went and had the window resealed and that same day the cargo/third brake light gasket started to leak!!! So when you guys are washin the truck, take a look at the window!!! They had 2 Rangers in that day at the auto glass shop and they both were 98s' If you do your own water test, and see the water is flowing threw the metal seem just over the head liner it is the cargo light gasket. My window leaked on the two upper corners. To reseal the window was $80, the cargo light gasket, which is sold as a assembly (thank you Ford) is just under $60. Stay dry guys!!!
Old Jun 24, 2002 | 10:05 PM
Sawbones25's Avatar
Sawbones25
Leaky rear window
My '95 leaked also. I sealed the window with some clear silicone. I just made sure it filled in the small crack between the rubber seal and the body. Haven't had any leaks since doing that. Of course, my carpet got ruined before I fixed the leak, so that has to be replaced or cleaned really well now.
Old Jun 25, 2002 | 08:06 AM
Ken00's Avatar
Ken00
Leaky rear window
MJFNH
2009 - 2014 F150
Mar 15, 2015 02:46 PM
Paulford8
2009 - 2014 F150
36
Jan 3, 2012 04:41 PM
mfp4073
Apr 18, 2010 10:10 PM
rjb03
Bronco II
Dec 6, 2005 06:52 PM
jbondi
1978 - 1996 Big Bronco
Apr 5, 2005 10:46 PM
