I'm sure Dennis or someone here will have an answer . . . this is driving me crazy. When you use quotation marks do they go before or after your period or other punctuation ending the senctence?
For instance, which would be correct here?
1. Ivan's motto is "bigger is better".
2. Ivan's motto is "bigger is better."
This always confuses me. It would seem that the punctuation should come after the quotation marks because it ends the sentence but it just doesn't look right for some reason.
In the first post, number 1 is correct. Punctuation within the quotation marks doesn't apply to the sentence started before the quotation marks. So example number two still doesn't have any puntuation to end the sentence.
I think that makes sense. So it depends on the context of the quote really, as to whether the quotation marks will be inside or outside the punctuation.
Actually, just the opposite. If the punctuation is part of the quote then put it inside the quote. That should not affect the sentence structure outside of the quotes.
