Has anyone done the lift in the rear where you drill the rivits out on the rear shackle brackets to get them off the frame and install them upside down and flip the shackle?. Does anyone know how much lift you get from doing this? I want to do this on my f250 crewcab.
yes I have, you mean like <A href="https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=58440&width=0">this</a> right?
you will get aprox. 3"... I usedto remember the exact amount but it has been a few months since I have done it.
<a href="https://www.ford-trucks.com/user_gallery/displayimage.php?&photoid=58439&width=0">this</a> is a comparison between a 2wd and a highboy, they both have the same tires on them but sit almost the same in the rear with the flip on the 2wd.
Check my 78 gallery for before and after pics of the shackle itself to give you an idea. I'd agree, 3-4". I'll be switching to a different bracket this week to increase the amount of lift.
I have 6" springs and extended shackles up front though I will probably fo back to stock shackles and extend my hangers to improve my pinion angle up front. DO NOT use blocks on the front of your truck.
I read in the factory Ford manual that any rivet in the frame that is removed should ba replaced with a grade 8 bolt one size bigger than the rivet it replaced!
Today i tried the flip on my 75 f250 crewcab 4x2 and it lifted my truck about a half inch. Lots of work for nothing gotta love it.I looked at the pictures on ivanribic gallery and it looks like the shackle on the 4x4 is longer.Can someone get me a measurement of the distance from bolt center to center on the 4x4 rear shackle?The one off the 4x2 is only 4"long. kjkozak2 What angle should the shackle be when sitting level?
I've posted a picture of your ideal shackle angle below. Ignore the shackle angle in my gallery . . . it's only temporary until I install the new brackets.
I don't know how you only got 1/2" of lift out of that flip. I'd say my shackles are right about 4" and I got almost that much lift out of them. You can also build longer shackles or buy them. If nobody else answers I can give you exact measurements off my shackles on Thursday.
