What`s the real diffrence Between 2004 and 2005
Old Nov 7, 2004 | 12:24 AM
shocktower's Avatar
shocktower
I really wanna know what make`s them so diffrent ,cause i can get a new `04 pretty cheap 6.0 PS 4x4 CC TF trans FX4 package on it ,I think I can get it for about 35.500 to 36,500
Old Nov 7, 2004 | 08:37 AM
04superduty's Avatar
04superduty
the front end is different, they went from leaf springs to coil springs. the grill, bumper and head lights are different. The engine has more power and the GCWR, GVWR, and towing capacities all went up. There is an trailer brake controller installed from the factory, and i believe on certain models there are upfitter switches. i am sure i missed something but someone will come along sooon.
Old Nov 7, 2004 | 09:33 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Go drive an 05 it is unreal the differences....
Old Nov 7, 2004 | 12:31 PM
Todder's Avatar
Todder
Yup, my uncle got a '05 last month and man that thing is almost night and day different than mine. Less turbo lag, and a much nicer dash.
Old Nov 7, 2004 | 12:57 PM
jdadamsjr's Avatar
jdadamsjr
Man, I've fought this...
but the real difference between 2004 and 2005 is .....
One... (or negative 1)
2005-2004 - 1
sorry - I actually waited DAYS to post this
Old Nov 7, 2004 | 01:04 PM
SBV45's Avatar
SBV45
and more money? Some differences in the engine:
1 Deleted intake throttle – instead added air flow “directors” inside RH exhaust tube & intake manifold.
2 New air inlet elbow to replace the throttle
3 Replace Rexroth high pressure pump with Shepard pump.
4 Replace Injection Press Relief (IPR) screen with perforated plate style filter – allows finer filtration (150 vs. 200 micron).
5 Water inlet relocated on front cover to accommodate new steering gear
6 New fuel supply and return pipes to accommodate water inlet
position
7 Improved EGR valve, increased flow, required for emissions.
8 Intake Manifold, EGR Distribution
9 Turbo Upgrade for flutter improvement
However, the most recent flash on my 03 fixed any lag issue and the EGR is still connected.
Old Nov 7, 2004 | 01:06 PM
sanpanchosue's Avatar
sanpanchosue
2005-2004 - 1
You got online way too early this morning jr. You could have waited a few more days.
Old Nov 8, 2004 | 08:43 AM
jfralph's Avatar
jfralph
What? Nobody going to mention the bigger = better brakes!!!
Old Nov 8, 2004 | 09:16 AM
shocktower's Avatar
shocktower
Ok thanks guys
I got me an '04 F-350 SD,4X4 CC,PS,LB,AUTO.Thanks for all the info ,but I think my new truck will suffice ,I just hope I don`t geta speeding ticket ,cause this thing is so fricking fast ,way faster than my '95 F-350 PS .I got are done with vynal floors in it cause it rains here some times and I get muddy ( I live in Oregon ,Molalla )
Old Nov 8, 2004 | 09:27 AM
Ophus's Avatar
Ophus
About the only thing that didn't change on them was the sheet metal.
Old Nov 8, 2004 | 10:20 AM
IB Tim's Avatar
IB Tim
They do have some massive breakes on them, differnt fame (10 to 17% increase), thicker, front axle 35 spline, different body mounts, ...shock stager....
Old Nov 8, 2004 | 03:55 PM
dPrasse01's Avatar
dPrasse01
All of the changes prompted me tgo buy an 04 to start my trucking business due to the lower cost of a lightly used 04 .... I'll trade up to an 06
Old Nov 8, 2004 | 05:45 PM
IB Tim's Avatar
IB Tim
That is not a bad idea, there are some smokin deals out there on the 04's...good call.
Especially starting a new business.
Old Nov 9, 2004 | 07:49 PM
04superduty
one more thing i noticed. on my truck there are inner fender wells on the rear but the 05's i looked at didnt have any.
Old Nov 9, 2004 | 08:25 PM
IB Tim's Avatar
IB Tim
Leaf's you can coils you can't....my bet anyway
