combustion chamber size????
Old 11-06-2004, 11:28 PM
busterc's Avatar
busterc
busterc is offline
Is there a way to make the combustion chambers smaller without milling the head???
I bought 9.0 -1 pistons (was very cheap) and actually need around 10-1 compression.
Old 11-08-2004, 01:21 PM
mako5972's Avatar
mako5972
mako5972 is offline
Not that I know of.
Old 11-09-2004, 09:43 AM
Mike G's Avatar
Mike G
Mike G is offline
First off, welcome aboard!
Secondly, your other option may be to go with a thinner head gasket. Check with the folks at your local machine or performance shop, they should be able to help you out. What motor are you working with and what are you doing with it??
--Mike
Old 11-09-2004, 11:13 AM
busterc's Avatar
busterc
busterc is offline
I'm working on a 1991 ford 302 H.O. motor.
I will have a 2500 stall in the trans. so I'm building it for mid and high rpm power.
On a Budget..............!
So far:
Speed Pro 9.0-1 coated Hyper pistons and chrome moly rings
Ford motorsports X303 roller cam
Weiand X-celerator intake
Road Demon jr. 725cfm
I am thinking of going with roller rockers with a higher ratio (1.7)?????
And all the normal block and head machine work.
ANY SUGGESTIONS????
Old 11-09-2004, 01:52 PM
samickguy15's Avatar
samickguy15
samickguy15 is offline
Cr
There is an option.....
You could weld up the combustion chambers and mill them back out. Chances are that this will kill your flow though.
Resto
05-24-2016 09:02 PM
ken1mod
Aerostar
23
03-10-2015 05:39 PM
Rusty_Old_F250
Large Truck
01-12-2015 10:30 PM
gbrett
04-04-2005 11:44 PM
Tiler
08-11-2002 05:10 PM
Quick Reply: combustion chamber size????
